Recomendations
riversidefort
Re: Recomendations
just out of curiosity how much did you pay to have the pistons dished?
- oletshot
Re: Recomendations
Sorry fedrusion, I missed your question about the depth. It's .200" from the top face of the piston.
Riversidefort, I did them myself, I program and run a CNC milling machine for a living. PERKS!
I've done stock pistons for myself and silvolites for one of the guys on the yahoo group. Still have the fixturing, PM me if you need someone to machine some.
'98 XJ 2-door, '94 YJ.
riversidefort
Re: Recomendations
i must say, that is quite the perk
- Shark
Re: Recomendations
how much would you charge to machine a set of pistons?oletshot wrote:Sorry fedrusion, I missed your question about the depth. It's .200" from the top face of the piston.
Riversidefort, I did them myself, I program and run a CNC milling machine for a living. PERKS!![]()
'95 XJ 4door 4.0 aw4 2" 31's
- oletshot
Re: Recomendations
Are you supplying them?how much would you charge to machine a set of pistons?
- Shark
Re: Recomendations
sureoletshot wrote:Are you supplying them?how much would you charge to machine a set of pistons?
- oletshot
Re: Recomendations
PMed you.tigerShark wrote:sureoletshot wrote:Are you supplying them?how much would you charge to machine a set of pistons?
- fedrusion
- Learning to use the board
Re: Recomendations
I've got my extra set from the 4.2 that I'm going to play around with at work before I try to dish the pistons from the 4.0 that I'm planning to use. Thanks for the depth.
riversidefort
Re: Recomendations
out of curiosity, have you completed the motor those pistons you machined are going into? if so, how are they doing?
- oletshot
Re: Recomendations
Haven't finished the build, yet. Even after finishing the engine, before it can be installed, I need to aquire all the parts necessary to swap a 4.5/AW4 combo into a 2.5/30RH YJ.
