Comanche91
Posts: 156 Joined: February 13th, 2008, 4:51 pm
Vehicle Year: 1991
Vehicle Make: JeeP
Post
by Comanche91 » April 15th, 2008, 9:52 am
FrankZ wrote: I run Bosch Platinum 4's. I tried the xtock Champions and got alot of noise on my stereo and CB...weird but true.
I had a lot of noise also on my stock 91 AM/FM/Cassette player too, but swapped in a single DIN Mitsubishi AM/FM/CD player in it's place and no more static. Must be filtered better.
91 Comanche LWB, AW4, Hesco 4.6L, D44 Trac-lok, CHROME freak , ROLL TIDE
Posts: 5790 Joined: February 14th, 2008, 7:14 am
Post
by SilverXJ » June 23rd, 2008, 8:25 pm
Has anyone tried an E3 spark plug yet? Looks ours would tale the E3.64 Champion RC9YC crossover).
-Chris
Posts: 635 Joined: May 22nd, 2008, 11:57 pm
Vehicle Year: 1980
Vehicle Make: AMC
Vehicle Model: Spirit
Post
by amcinstaller » June 23rd, 2008, 8:40 pm
i have never seen E3s around. my favourite local partsman is starting to think theyre a myth
SilverXJ wrote: Roller rockers won't help that mess you have created. Nor will God for that matter.
Post
by SilverXJ » June 24th, 2008, 6:02 am
Advanced sells them over here.
Vehicle Year: 1980
Vehicle Make: AMC
Post
by amcinstaller » June 24th, 2008, 5:46 pm
where is here? im in canada, and i think ive seen them on tv......once.
Post
by SilverXJ » June 24th, 2008, 7:55 pm
Virginia
rkcrwlr
Posts: 1 Joined: June 5th, 2008, 9:48 am
Post
by rkcrwlr » June 25th, 2008, 12:00 pm
FWIW, Golen calls for Autolite 985s gapped 0.040 in thier strokers.
crustodd
Posts: 146 Joined: November 18th, 2008, 4:29 pm
Stroker Displacement: 284
Vehicle Year: 1994
Post
by crustodd » November 22nd, 2008, 2:03 pm
What happens if you're running an after market ignition? I have a full MSD set up (overkill?) It fires triple the normal rate below 3K. Suggestions?
Posts: 709 Joined: February 13th, 2008, 8:35 pm
Post
by John » November 22nd, 2008, 2:42 pm
What does MSD recommend?
crustodd
Vehicle Year: 1994
Post
by crustodd » November 22nd, 2008, 8:12 pm
I haven't checked with MSD. Didn't think of it.
Mgardiner1
Posts: 574 Joined: August 2nd, 2008, 6:19 pm
Stroker Displacement: 284 CI
Post
by Mgardiner1 » November 23rd, 2008, 5:16 am
Does your MSD box allow you to adjust ignition timing? I know not all ignition boxes are capable of that, some just make a hotter spark
oletshot wrote: ....and silvolites are only cast not
hypericantspellits .
crustodd
Vehicle Year: 1994
Post
by crustodd » November 23rd, 2008, 8:24 pm
My MSD box does allow for that, but I didn't get the controller for it as I didn't think i'd be using it to that extent. I know, OVERKILL! Maybe with a stroker, it will be of some advantage.
daccarettfletez
Posts: 22 Joined: September 4th, 2008, 5:22 pm
Stroker Displacement: 4.5
Post
by daccarettfletez » February 6th, 2009, 1:34 pm
I'm also running an Msd 6 in my 4.0 with a firepower coil, summitracing 8mm cables and been using the accel yellow u groove plugs (any good?) gapped at .45, My engine is torn down in the process of becomiing a 4.5 poor man's stroker (4.2 rods, crank, 4.0 pistons dished to 23cc, no overbore, no decking, victor reinz head gasket, at sea level) do you think they will still work or should I switch to the champion rc9 or rc10 plugs?
Comanche91
Vehicle Year: 1991
Vehicle Make: JeeP
Post
by Comanche91 » February 6th, 2009, 2:04 pm
I've tried NGKs, Bosche, Champion "Truck" plugs, etc. ad nauseaum. Nothing works better for me than the old school RC9 or RC10 copper cores. They are recommended both by Mopar and Hesco for the OBDI NA and strokers; I'm stickin' with them.
Posts: 1353 Joined: February 13th, 2008, 5:33 pm
Post
by gradon » February 6th, 2009, 11:58 pm
I have the rc9s in mine. I loved the Autolites double plats on my 4.0.
