Newbie in need of advice and recipe
yuppiexj
Re: Newbie in need of advice and recipe
Post by yuppiexj »
IIRC CA models from 81-
49 state from 87-
87 Wranglers 4.2l were serpertine
Post by John »
You do not have to machine the long snout crank down for a serpentine drive, you could also use a spacer as I commonly do.
cjackson3396
Post by cjackson3396 »
Would I have to do any machining to the crank...at either end?
cjackson3396
Well just to make things easier lol the 4.2 I have is a 82.
yuppiexj
Post by yuppiexj »
does your 1982 4.2 have a serpentine belt drive on it?
If it does you are good to go, if it doesn't you'll need the spacer.
if you only have a bare block and crank you'll have to check casting numbers. (3727 is a serp drive)
you could measure the snout as well.
see the FAQ for more info on casting numbers.
http://www.jeepstrokers.com/forum/viewt ... ?f=34&t=51
