'99 MJ Project - Possible Stroker Build - HELP
go4lo
Vehicle Model: MJ
Re: '99 MJ Project - Possible Stroker Build - HELP
Post by go4lo »
gradon wrote:Someone posted a few weeks ago a link to the KB944s that could be had for ~$350, so search around here. I don't know if that included the rings.
Thanks for the tip! I found the old post. Looks like they've gone up slightly on their price but still not bad. $425.00 for a set of the KB944s and $65 for KTM Molly rings.
http://www.cnc-motorsports.com/product. ... 443&CtgID=
If I'm correct I should be able to order these, use my stock 4.0L rods, and a 4.2L crank?
No block or head shaving required?
Plechtan
Post by Plechtan »
Plechtan wrote:As far as your choice of parts, i would stick with the 4.0 rods and use the KB944 pistons. By the time you buy new rods, and get the pistons dished deeper, it is just eaiser.
Like i said
Peter Lechtanski
Yep, their price has gone up. Still cheaper than summit or 505 performance.
go4lo
Vehicle Model: MJ
Post by go4lo »
Like i said
Opps.....sorry :doh:
Thanks for reposting. I'm still a newb to the stroker world so please forgive me.
Just for clarity sake, if I go with the KB944s I "should" be able to reuse my 4.0L rods and no dishing is required to these?
LetchcoreCJ7
Learning to use the board
Vehicle Year: 1983
Vehicle Model: CJ7
Post by LetchcoreCJ7 »
Yes you use the 4.0l rods and they come with at decent 9.5 to 1 compression ratio. No need to dish them.
1983' Jeep CJ7 w/ 4.6L stroker, NSG370 6 speed trans, D300.
91' 4.0L engine, 0.030 over, 4.0L rods, 4.2L crank, KB944 pistons, Stock head w/ Mopar springs, Mopar cam, Mopar roller timing chain, Mopar oil pump, Hesco CPS relo kit, SS header
