air fuel ratio gauge?
woodjeep
Re: air fuel ratio gauge?
I hung a different meter on it this afternoon for the drive home, a little better scale in the volts range ...much easier in the daylight. Started showing voltage within a minute of startup. Once warm..idle flux between .55 and .7 fairly steady and constant rate of cycling. if it swung past .75 the next swing would take it a little below .5 Cruising at 60 with the cruise control on it basically sits at .55 to .6 Large changes in the gas ( around 1000 rpm) would make it drop to about .25 for a split second then go right back to around .6. It looks like the system wants to maintain a mixture that gives about .6 volts. Next I need a vaccum gauge to see how thats working but pretty interesting so far
cherokee
- Vehicle Model: Comanche
Anybody figured out a good way to read off of the renix 5v o2 sensor?
98XJ 2dr. little lift, lotta skidplate
88MJ some assembly required
woodjeep
I am not familiar with the renix o2 sensor but you could probably do what I did and just splice into the output wires and read the resulting voltage on a voltmeter. Its not pretty or permanent but it will give you an idea of whats going on.
jbxx
- Vehicle Year: 1986
- Vehicle Model: CJ7
Renix
o2 low (rich) <2.5V.
o2 high (lean) >2.5V.
J.B.
J.B.
