Megasquirt program
shawnxj
- I love this board
- Vehicle Model: cherokee
Re: Megasquirt program
what year flywheel and sensor are you running?
gsune
- Stroker Displacement: 4.5
- Vehicle Model: cherokee x
my cherokee is year 2000 with a 3 wire hall sensor
http://www.cherokeeforum.com/members/fu ... linder.jpg
flyweel pattern is: http://www.msextra.com/doc/triggers/jeep2000-ang.jpg
thanks you a lot
thanks you a lot
jeepxj3
- Vehicle Model: xj
Great pic of the flywheel and the divisions.
- PseudoSport
- Stroker Displacement: 4.0L Turbo
- Vehicle Year: 1995
Correct me if i'm wrong but I think only MS3 has the coding to support the 2000 trigger wheel. MS2 will only do the renix one.
GRM Challenge 1995 2WD Cheorkee, 2,780lbs, 240k 4.0L, 50 trim T3/T4 turbo, MS1 EFI, 36lbs injectors, -2.5 degrees camber, Ford 8.8 3.73 w/LSD, 274 whp/322wtq, 12.98@100mph 1/4 mile
http://www.Facebook.com/JeepXJR
1982 AMC Spirit - Turbo 4.0L, 60 trim T3/T4, MS1 EFI
JesseByrd
so you CAN run a MS with the stock renix fly wheel/cps. i had thought you would have to convert to a balancer mounted set up...other than trans options is there any benefit to balancer mounted???
gsune
the sensor in the balancer is at lower temperature than the stock posicion
the hight temperature always damage the sensor
( sorry my english )
- PseudoSport
The Jeep Renix trigger wheel is pattern is 66-2-2-2. In MS2 it’s under Renix 44-2-2 but when you select 6 cylinders instead of 4 it will use the 66-2-2-2 code. Cam signal should not be needed.
For MS1 you would need to run a 36-1 trigger wheel on the balancer or use a 91-93 4.0L distributor with a ford 6 vane shutter wheel. 4.2L distributor is also an option.
beiwulf
- Vehicle Make: ZJ
- Vehicle Model: Laredo
Is there anyone currently active on board running an MS3 setup with stroker/boosted setup?
I'm considering MS3 over an OBDII conversion w/factory harness… Why??..
From what I have read MS3 can handle.
-boost control
-fuel mapping
-coil pack setup
-voltage ramp for electric fan(s)
-ign timing/spark
-MAF
-allow for future upgrades like cam dry sump setup.
-everything ecm factory does
cost for an external voltage ramp/relay just for fans will run me $175-300- depending on which one i use. Isn't that what it cost just to buy an MS3 and put together?
Thanks,
Brian
-boost control
-fuel mapping
-coil pack setup
-ign timing/spark
-MAF
Thanks,
Brian
gsune
Hi . i´m running ms2 V3 fuel only 36-1
