Page 2 of 2
				Re: Megasquirt program
				Posted: July 10th, 2014, 7:33 pm
				by shawnxj
				what year flywheel and sensor are you running?
				Posted: July 12th, 2014, 5:30 am
				by gsune
				Posted: July 12th, 2014, 7:44 am
				by jeepxj3
				Great pic of the flywheel  and the divisions.
				Posted: July 13th, 2014, 8:05 pm
				by PseudoSport
				Correct me if i'm wrong but I think only MS3 has the coding to support the 2000 trigger wheel. MS2 will only do the renix one.
				Posted: August 4th, 2014, 1:20 pm
				by JesseByrd
				so you CAN run a MS with the stock renix fly wheel/cps.  i had thought you would have to convert to a balancer mounted set up...other than trans options is there any benefit to balancer mounted???
				Posted: August 4th, 2014, 5:17 pm
				by gsune
				the sensor in the balancer is at lower temperature than the stock posicion
the hight temperature always damage the sensor
 ( sorry my english )
				Posted: August 8th, 2014, 4:39 pm
				by PseudoSport
				The Jeep Renix trigger wheel is pattern is 66-2-2-2. In MS2 it’s under Renix 44-2-2 but when you select 6 cylinders instead of 4 it will use the 66-2-2-2 code. Cam signal should not be needed.
For MS1 you would need to run a 36-1 trigger wheel on the balancer or use a 91-93 4.0L distributor with a ford 6 vane shutter wheel. 4.2L distributor is also an option.
				Posted: March 2nd, 2015, 1:03 pm
				by beiwulf
				Is there anyone currently active on board running an MS3 setup with stroker/boosted setup?
I'm considering MS3 over an OBDII conversion w/factory harness… Why??..
From what I have read MS3 can handle.
-boost control
-fuel mapping
-coil pack setup
-voltage ramp for electric fan(s)
-ign timing/spark
-MAF
-allow for future upgrades like cam dry sump setup.
-everything ecm factory does
cost for an external voltage ramp/relay just for fans will run me $175-300- depending on which one i use.  Isn't that what it cost just to buy an MS3 and put together?
Thanks,
Brian
				Posted: November 29th, 2018, 7:07 pm
				by gsune
				Hi . i´m running ms2 V3 fuel only 36-1
