PSC1-003 Install Questions
Winners97TJ
Learning to use the board
Stroker Displacement: 4.7L - In Progress
Solution....
Post by Winners97TJ »
Winners97TJ wrote: Anyway, I got to trying to reinstall this thing again here is my wiring;
Red - 12V switched power
Black - Ground
Yellow/Black - tapped into Tan/Yellow Tach signal
Green - Sensor side of MAP-to-PCM wire (Green/Red)
Violet - PCM side of MAP-to-PCM Wire (Green/Red)
Red/Black - 5V Sensor power
and what I have found out is that the pressure is stuck at 5.5 constantly. No change at all. Not even if I drop the values in R4.
Wow... I mean, F***in WOW!! This has been such a nightmare, but some of it has been self-induced. Let me explain...
The reason there was no change in the reading and the check engine light came on when hooked up this way was because when I disconnected the MAP sensor to double check wires... I FORGOT TO PLUG IT BACK IN!!! :brickwall: :doh: :smack: (Yeah, I know. What an IDIOT!) It's amazing what happens when there is actually a SIGNAL to modify running down those wires!
Thank you everyone who has had a hand in this fun. It is running great, tuning well, and working as it should. FINALLY! :banana: :rockout:
Now if we could only get a version of R4 to work with my laptop and the newer Windows7......
Re: PSC1-003 Install Questions
Way to stick it out! You know the PSC1 I have was originally bought from and tuned by 505 years ago(I didn't know about them at the time, but they are one of the few co.s that are taking Jeep performance to higher levels)--another meant to have part(30ab cam was made on my birthday).
