Tune with Split Second
montelibre
Re: Tune with Split Second
Post by montelibre »
Some pics:
Currently, the pulely is smoller than in the pics.
http://www.jeepstrokers.com/forum/viewt ... f=5&t=2173
Wenrickt
Vehicle Model: Tj
Post by Wenrickt »
montelibre wrote: June 21st, 2012, 2:19 pm Now I have got 12,5/1 AFR at WOT with current maximum boost (5 psi) and 30 lbs/hr injectors. :banana:
This is the map:
5 Psi 30lb-hr 23-03-2012.mdb
Thanks you all again.
Hey man is there anyway you can send me the map you ended up using I’m having struggles running the same set up
the grey ghost
Stroker Displacement: 4.611
Vehicle Model: comanche
Post by the grey ghost »
Yeah I'd like to take a look at it too
RedTurboJeep
Stroker Displacement: 4.6Liter
Vehicle Model: Zj Laredo
Post by RedTurboJeep »
Hey guys I'm new to the forum I just bought a boosted crate from Golen engines it's a 4.0 stroked to a 4.6 liter it's got scat4340 forge rods& pistons HO head a cam from comp cams are head bolts and I'm using a Garrett 50mm turbo , a 38mm tial wastegate on 8lb tune from split second ....... I guess my questions is are there any other tuners that work like a standalone that don't integrate with the pcm to trick the stock brain into thinking there's no boost running through the jeep are there any real ecu for boosted application's and there any upgrades I can do to the engine regarding intakes ect
Cummins90
Post by Cummins90 »
Ryan may be able to help you
https://www.frptuning.com
Or Kevin possibly
https://sykedecutuning.com/store/index.php
Neither one does canned tunes (prebuilt tunes) all need to be datalogged and built individually.
I am running an AEM FIC 1913. The whole experience got better once I got the injector dead time and map clamp dialed in.
mpampismykonos
Stroker Displacement: 4.0
Vehicle Model: Tj
Post by mpampismykonos »
Hello . i have a tj4.0 with supercharger, split second ftc 202, is there any map that can work properly? i have the split second map 2) For 6 psi amplifiers and 30lb FTC1-019 6lb base map.mdb injector.
Bguse1983
Vehicle Model: Tj
Post by Bguse1983 »
montelibre wrote: June 22nd, 2012, 12:58 pm Some pics:
Do you still have the ss tune?
Would you mind sharing it with me?
Good luck getting a response 8 years since his previous post. :lol:
Cummins90
Post by Cummins90 »
Start a new thread and post up what you have so far. Someone may be able to help you out. Details about your engine will help as well.
Jroch99
Post by Jroch99 »
Any chance of posting that map again ?
Mike B
Vehicle Year: 1995
Vehicle Model: Xj
Post by Mike B »
Jroch99 wrote: October 18th, 2020, 12:48 pm Any chance of posting that map again ?
Check the dates on the original post bud, not to mention the guys above ya just stated its an 8 year old thread. Chances of this guy responding are next to zero, but there have been suggestions made as to who may help ya. Look up a few posts....
