Recommend a stroker for a 4500 Ultra4 Jeep
hurleygo3
Re: Recommend a stroker for a 4500 Ultra4 Jeep
I about to drop this motor in this weekend. But I need to figure out what injectors I should run. Thinking about 24lb Ford ev6 injectors. This a good starting point?
- Stroker Displacement: 4.9
That engine sounds like Gerald Lee and John s from the LJ.hurleygo3 wrote:I about to drop this motor in this weekend. But I need to figure out what injectors I should run. Thinking about 24lb Ford ev6 injectors. This a good starting point?
Do I get a cookie ??
hurleygo3
Why yes it is. When I got the motor from Gerald it had a melted piston in #6. So I'm try to keep that from happening again.jsawduste wrote:That engine sounds like Gerald Lee and John s from the LJ.hurleygo3 wrote:I about to drop this motor in this weekend. But I need to figure out what injectors I should run. Thinking about 24lb Ford ev6 injectors. This a good starting point?
PM senthurleygo3 wrote:Why yes it is. When I got the motor from Gerald it had a melted piston in #6. So I'm try to keep that from happening again. :mrgreen:jsawduste wrote:That engine sounds like Gerald Lee and John s from the LJ.hurleygo3 wrote:I about to drop this motor in this weekend. But I need to figure out what injectors I should run. Thinking about 24lb Ford ev6 injectors. This a good starting point?
Do I get a cookie ?? :hrhr:
hurleygo3
Well, I won a set of brand new Bosch 27lb ev6 injectors on Ebay. $38 for six. For that price I couldn't pass them up.
hurleygo3
Drove it for the first time this weekend. Had Chris tune it and ended up with a set of Ford 27lb injectors. Runs great. It's spin the 37's and barks the tires into 2nd. Very happy with the power. Only issue was a oil leak at valve cover. Not sure what it will take to fix. The Hesco head casting is different and the gasket doesn't line up at the rear.
Looking good Mike !
Glad to see that Chris was able to help you out with tuning.
As ridiculous as it sounds I still have a 50/50 chance of making it to the lakebed. Be staying with Blaine, Gerald Lee and the gang if I make it. I`ll be looking for you if so.
Keep us posted on how it works out.
Maybe give Bennie a call on the gasket. They ought to have a solution.
HESCO Inc.
1200 2nd Avenue South
Birmingham, AL 35233 US
Phone: (205) 251-1472
Fax: (205) 251-8358
email: [email protected]
Our office hours are Monday - Friday from 7.30 AM until 5.30 PM CST
http://www.hesco.us/
HESCO Inc.
Fax: (205) 251-8358
Are you using the aluminum or steel valve cover?
hurleygo3
Thanksjsawduste wrote:Looking good Mike !
HESCO Inc.
Fax: (205) 251-8358
Already talked to Bennie. He said use the gasket that I already was using. Hope you make it out there.
hurleygo3
I have the factory 2000 steel cover on there now. I have a Crown aluminum cover but the holes don't line up so I haven't tried that one.SilverXJ wrote:Are you using the aluminum or steel valve cover?
Using the blue rubber felpro gaskets.
Thanks
hurleygo3
Well I killed the Hesco stroker
Got about 50 miles out of her.
So after talking with some people that know a lot more about strokers than myself. Thanks John. I'm building a new motor that should have a good mix of power, torque and run a little longer than 50 miles.
Specs
95 block bored .030 over and the deck cleaned up
7120 head with LS valves and springs with a little cleaning
SCAT crank
SCAT forged rods
Set of custom Diamond pistons to get a zero deck height
Roller rockers and a Hesco cam
Double roller
Hesco oil pump
OBDII with a coil pack
ECM will be tuned by Chris
Borla Headers
2001 intake
62mm TB
The motor will be blue printed and balanced. As soon as I pick the block up I will start the build.
Specs
SCAT crank
SCAT forged rods
Double roller
Hesco oil pump
Borla Headers
2001 intake
62mm TB
Damn.. that hurtshurleygo3 wrote: Got about 50 miles out of her.
Which SCAT rods?SCAT forged rods
That guy is good!ECM will be tuned by Chris
shawnxj
- I love this board
- Vehicle Model: cherokee
how'd you break the hesco?
hurleygo3
Haven't pulled the hesco apart yet. I lost it pre-running 3 days before KOH. I lost a fuel pump and think it went lean. Didn't have a air/fuel gauge. That's going to change
SCAT just released rods.
