2000 tj have thrust plate?
fsjeep13
Re: 2000 tj have thrust plate?
Post by fsjeep13 »
This is the cam I have.
http://www.summitracing.com/parts/cca-68-200-4
valve springs: SBI 32-2225 it looks like. I can't find info on those.
There is a Melling VS225, which is a stock valve spring.
Did you see the bolt from the cam gear? What about the front of the cam gear?
Those two cylinder may have a bit of coolant coming in but they don't look that bad, did you notice a coolant loss? I don't see any definitive proof on that. I'd be more concerned with the chain someone left in there.. couldn't have been good for the valves and pistons running like that.
fsjeep13
Post by fsjeep13 »
I could not find the bolt from the cam gear... The front of the cam had a pin ill call it that would fit into the gear so they stay together.
I6FAN
Stroker Displacement: 4.2
Vehicle Year: 1987
Post by I6FAN »
That top bolt hole, for the retainer plate, looks like it has a lot of oil in it compared to the bottom hole. There isn't a "tap" into the oil system in there is there? Just brain stroming, maybe that hole needs to be plugged?
Knoxes
Vehicle Model: GC
Post by Knoxes »
Not sure if the info I got from Jones still applies to this thread, so I posted it in my build thread.
http://www.jeepstrokers.com/forum/viewt ... 952#p34952
2004 WJ 4.7L HO
