Stumble when cold
joeguyzxj93
- Vehicle Model: cherokee
Re: Stumble when cold
Does anyone know what injectors would work best for me ? Maybe from a 99 cherokee I can run to yard tommorow and grab a set ,
joeguyzxj93
Ok did some research on here from what I gather blue ford injectors or 99 Jeep Cherokee injectors wil be fine to swap out for my heep . If I am wrong can someone please correct me
Where are you reading that? 99 XJ injectors are only 22.5 lb/hr. What is the part number for a ford blue injector?
joeguyzxj93
I was looking at different sites on internet What injectors would you suggest ? Looking to pull them from yard
Try your spare '93 injectors. In your 49psi fuel system they'll flow 23.5lb/hr and that might just be enough.joeguyzxj93 wrote:I was looking at different sites on internet What injectors would you suggest ? Looking to pull them from yard
Retlaw01XJ
- Vehicle Year: 2001
Injector # 0-280-155-784 from a Neon work well. Also used in some mini vans.
Not all engine sizes used this injector, so keep looking till you find the right ones.
A search here for 'Neon injector' or '784' will give you more info.
Walt K
Eastern Pa
Eastern Pa
sly-jeeper
- Vehicle Year: 1994
any luck?
joeguyzxj93
Haven't tried it yet . Work has me busy .
joeguyzxj93
Got some time and put in stock injectors and it seems to be a little better . I haven't driving it yet due to lifting it . Going to yard Sunday to see about getting 784 injectors
joeguyzxj93
Got my lift done and new battery last night I tried to fire up the jeep to move it outta the garage and it wouldn't fire I checked the fuel pump and found the positive wire was on broken and prob was for a long time the wire was corroded and burnt up from the connection being no good . Got it to fire and called it a night . Wondering if the pump is cutting out or not getting enough power . Won't know if it helped the problem until next weekend . I have to go across the country for work this week !
joeguyzxj93
Got the new 784 injectors and clips my old clips don't line up with new injectors . Same colors though can I splice into these ?
the Neon 703 injectors may have suited you better as they are the square socket. But you can definitely change the connectors without issue.
joeguyzxj93
Got the injector plugs in last night and the injectors also put in a accel coil everything seems to run smoother but haven't drove it yet hopefully tonight
Retlaw01XJ
I didn't realize your '98 used the older style plugs. Looks like they changed the connector for '99-up. My apologies for giving you bad info.joeguyzxj93 wrote:Got the new 784 injectors and clips my old clips don't line up with new injectors . Same colors though can I splice into these ?
Walt K
Eastern Pa
Eastern Pa
joeguyzxj93
Not a problem changed plugs fairly easy found that I have 1 bad o ring its leaking .everything seems much better
