Injectors
FlyinRyan
Re: Injectors
Non-OEM injectors should always be tuned via reprogramming the PCM, due to differences in injector characteristics. My .02
wjtom
- Vehicle Year: 2001
- Vehicle Model: wj
Re: Injectors
Guys hes right if youve ever had the opportunity to data log when making changes to the fuel system the changes can by quite drastic.Just changing the output of the fuel pump not the actual operating pressure of the fuel system will have an effect as will the injectors.You will see definite results when these are properly adjusted for.If you search ford injectors they have some good comparisons to the same size injectors but with different characteristics.Ie a stock ford 24lb injector is not the same as a ford motorsports 24lb injector as far as tuning goes.There is more too it than just swapping injectors.Yes you can do it that way but it isnt ideal by any means.
RenoF250
- Vehicle Year: 1985
- Vehicle Model: CJ7
Re: Injectors
I thought pre-OBDII cannot be tuned??FlyinRyan wrote:Non-OEM injectors should always be tuned via reprogramming the PCM, due to differences in injector characteristics. My .02
RenoF250
Re: Injectors
RockAuto has new 24.6# 53030262 injectors whoelsaler closeout for $26 so I ordered those. That should provide the right amount of fuel and they are new so for now I am
wjtom
- Vehicle Model: wj
Re: Injectors
Thought a while back there was someone on here that said he could do pre obd2.I do know from experience that having the right parameters for the injectors definitely makes a difference.
Re: Injectors
RenoF250
Re: Injectors
Thanks, I just e-mailed him.
RenoF250
Re: Injectors
Well I e-mailed him a few days ago still no response. I went to christune.com and it is a guy that play in a jazz band, no mention of PCMs, I think you were having a little fun with me.
It should still run okay without being tuned just better if tuned right?
Re: Injectors
Hell.. my fault... its [email protected]...
RenoF250
Re: Injectors
That looks better thanks!SilverXJ wrote:Hell.. my fault... its [email protected]...
Do you know how it works? Do I send him the computer? What does he tuned based on? Configuration? Run it and on the computer and then tune based on teh adjustments it makes?
