Injector Advice Needed
Re: Injector Advice Needed
Burnsmacdonald wrote:Accel 24lb injectors worked great. Mixture was a bit rich at first but has evened out and is good now.
Picked up a new fuel rail. Amazingly, the injector clips are ridiculously expensive, but I replaced them anyway, as everything else is new and the old ones were rusty.
Very good throttle response and smooth idle.
Didn't need the EV adapters as the Accel injectors matched the OE harness.
Glad the Accel injectors worked out for you though I would have been surprised if they had turned out otherwise.
My mistake about the EV adapters. I'd forgotten that the stock injector wiring plugs were EV6 only from '99 onwards.
