Can advancing Cam 4deg, cause a P1391 code
rwkhaussupply
Learning to use the board
Re: Can advancing Cam 4deg, cause a P1391 code
Post by rwkhaussupply »
ok so...
If I adjust the Dist housing retarded, it does not throw a code but runs with what feels like less higher RPM power. I am trying to get it as far clockwise as I can without a code and then go from there I guess.
jeepxj3
Vehicle Model: xj
Post by jeepxj3 »
You advanced the cam 4* and
'Advancing the camshaft timing in relation to the crankshaft will lower the power curve range on your engine. This means that the power curve will start at a lower rpm. Retarding the cam timing, increases the power curve - the power curve will start later at a higher rpm'.
Isn't that what you are seeing, less upper rpm power?
Why not take out the 4* advance that you put in and then run it and time it with the toothpick method. Wouldn't your cam/crank sync then be within range/spec and no code.
