First post for a jeep stroker
- Stroker Displacement: 4.9
- SkylinesSuck
Re: First post for a jeep stroker
Maybe I missed it, but I didn't see how much it weighed.
Really dude? The picture says "image is a representation of this item. Actual item may vary" Can you read, or are you just in a hurry to start an argument.
48 lbsSkylinesSuck wrote:Maybe I missed it, but I didn't see how much it weighed.
Really dude, have you tried Google images ? How about a search on this site ? I knew when I posted the link it would be questioned as Summit states clearly that it was a representative picture. Was curious if anyone would dig a bit deeperdwg86 wrote:Really dude? The picture says "image is a representation of this item. Actual item may vary" Can you read, or are you just in a hurry to start an argument.
Try opening 3 tabs. Search for all 3 flavors of cranks in Google Images and look to see the differences in the counter weights all at the same time.
You seem like a real nice guy but try being a little more creative
Not trying to pick a fight in any means. Finding solutions and learning on your own creates a better understanding. This crankshaft business is the backbone for any stroker build and one of the most common questions.
If you were asking something a little more techincal or complex then have at it.
The SCAT is a 4 cwt crank:
NCLJ
- Vehicle Year: 2006
- Vehicle Model: Unlimited
That was my next question! Thanks
NCLJ
Just wanted to say thanks for all those responding to my stroker needs. FYI dwg86 is a great individual to buy from, we got together on here and he shipped out a 4.2 12 wt. crank to me, seamless transaction, so thanks man!
Ok so I'm trying to deside if I should go 4.6 or 0.060 over 4.7. By the time I get around to doing this my jeep DD should be a weekend toy. One thing I've noticed with some of the 4.7l folks tend to have a 62cc on the cylinder heads, any problems doing the stock head (58cc) and maybe polishing the combustion chambers? Also I've noticed a pattern with going to a larger throttle body? I have an 2006 LJ and I've heard some problems with doing this.
Thanks guys.
Thanks guys.
- Strong Poster
Because 4.0 blocks consistently have thick cylinder walls my general recommendation is to go to a 3.935 .060 bore
Thanks. I hope that crank will polish up. You can save some money not having it turned.
NCLJ
Ok Russ, what would you say about any cooling issues?Russ Pottenger wrote:Because 4.0 blocks consistently have thick cylinder walls my general recommendation is to go to a 3.935 .060 bore
NCLJ
My guy said it looks good to him on the inspection. I'm planning on machine the snout for the harmonic balancer and I would like to balance everything out. That's why I was inquiry on the 4.6 or 4.7, I may go ahead and get my pistons and flywheel to do it all at one time here. Looks like it will work out!dwg86 wrote:Thanks. I hope that crank will polish up. You can save some money not having it turned.
- Strong Poster
No issues with going .060NCLJ wrote:Ok Russ, what would you say about any cooling issues?Russ Pottenger wrote:Because 4.0 blocks consistently have thick cylinder walls my general recommendation is to go to a 3.935 .060 bore
My race engines are running flattop pistons with a 3.970 bore
12.5:1 static compression and no overheating problems.
If you send me an email I'll be happy to forward you pricing and information on my Pistons.
Thanks,
Bishop-Buehl Racing Engines
531 N. Lyall Avenue
West Covina, California 91790
(626) 673-2203
NCLJ
PM sent..Russ Pottenger wrote:No issues with going .060NCLJ wrote:Ok Russ, what would you say about any cooling issues?Russ Pottenger wrote:Because 4.0 blocks consistently have thick cylinder walls my general recommendation is to go to a 3.935 .060 bore
Thanks,
531 N. Lyall Avenue
(626) 673-2203
