Hey all, I hope this is the correct topic to post in because i am definitely a noob. I have a 97 ZJ with a 4.0 that had a recent leak in he head. I have had it checked this week and the machine shop is telling me that it has a major crack and they do not feel good about attempting a repair. That being said i have decided that i will go ahead and build the stroker that i want. Like a lot of folks here i want to budget this out and spread the cost out where i can. I think the "Low-Buck 4.6" will fit me the best but i am unsure how to start.
Since i am not a machinist can you assist me on how to let the machinist know what i need done to the block at minimum. I want to do as much of this myself (outside any machining) that i can. Also is the Block even where i should be starting or does gathering all needed materials first make more sense? Thank you for any incite you can provide i am just needing to create a clear direction of how to tackle this project and dont want to miss anything.
stroker noob questions for 94 YJ
greers85
- Vehicle Model: Grand Cher
Re: stroker noob questions for 94 YJ
You can reuse the '97 block, oil pan, connecting rods, timing cover, cam bolt kit, oil slinger, and rocker arms/bolts for your stroker build but just about everything else will need to be replaced so start making a shopping list.
