4.6 liters stroker twinturbo charged
cobra96svt570
- Stroker Displacement: soon
- Vehicle Model: cherokee's
Re: 4.6 liters stroker twinturbo charged
Hey guys, Newb-E here.
Ive been looking thru' this forum for months now, and i finally made and account.
I have a bunch of toys, 2- xj's, a 96' cobra, 01' caddy, and have owned everything from 71' international dumptrucks,to RM250 dirtbike. So Im not a newbie to engines, suspension or anything that is propelled by a combustion engine,
but Im not an expert scientist either.
So I was wondering turbostroker', how exactly your distributor/coil setup work with the megasquirt?
Are you using a crank trigger of some kind?
What megasquirt are you using?
Ive had alot of experience with tuning ECU'S, and aftermarket standalone systems, And im really starting to like the megasquirt-DIYauto- setups. How do you like it? Is it fairly easy to learn?
thanks in advance
thanks in advance
- turbostroker
- Vehicle Year: 1991
cobra96svt570 wrote:Hey guys, Newb-E here.
thanks in advance
I like megasquirt because it's easy and cheep it's also do all the things that I need.
I use the MS2 with V3 board.
My ignition setup work like these, the megasquirt fire the spark depending on the cranktrigger but the megasquirt are set to control only one coil.
Then the distributor tells my circuit which coilpack the megasquirt should fire.
Now I have the new turbo setup ready and tonight I should change oil and fire it up for the first tim (I hope
Here are some picture of it.
Jeep Wrangler -91 Twinturbo 4.6 Stroker
Bo Wernersson
Bo Wernersson
- Mopud
- Stroker Displacement: 4.66L
- Vehicle Model: TJ
Fantastic work Bo, I admire your ingenuity! How did the first start go?
2001 TJ 4.66L
- turbostroker
The first start went well, some few fuel leagage but easy too fix.Mopud wrote:Fantastic work Bo, I admire your ingenuity! How did the first start go?
Now I have start too map the injection and are close too finish that.
I have also mount the new hodd with a scoope.
So far I very satisfied with the engine, great torgue and much more power than I need
Now I see forward too the first race with it.
Bo Wernersson
Bo Wernersson
israelcj7
- Stroker Displacement: 282
great build man love your work.
what scr are you running ?
any info on the engine internals?
500+ hp is sick, who needs sbc
- turbostroker
Here are the specifikations for the engine:
Mopar high volume oilpump
Molychrome piston rings
Cloyes true double roller adjustable
Mopar purple perfomance camshaft
Double valve springs
crankshaft 3214723 balanced
connecting rods 707 balanced
Keith black pistons 0.30 overbore
91:a engine block 0.30 overbore
Ported cylinderhead Mira grinded valves flow optimized
New manifold flow measured and optimized
New intake flow measured and optimized
2 st Td04-14T turbo chargers
3" exhaust
Megasquirt injection
730 cc injectors
Aeromotive A1000 fuelpump
Intercooler
3" exhaust
730 cc injectors
Intercooler
Bo Wernersson
Bo Wernersson
- turbostroker
Now my jeep is a Quadfuel and have run with gas for the first time.
It's built for unleaded petrol, Ethanol, CNG and hydrogen.
My plan is to make hydrogen at home with solarenergy so it's don't cost anything.
The microcontroller i have program so it's automatic runs on gas then I drive on bigger roads (speed sensitive) if the pressure is enought, if pressure is low it runs automatic on fuel again.
The gastubes came from a Ford Crown Victoria police car from USA a guy has imported to Sweden and disassemble the gassystem from the car.
Injectors and relay
Gastubes
Microcontroller and lcd display
Injectors and relay
Gastubes
Bo Wernersson
Bo Wernersson
kaputnik
Hi, what Mikrocontroller are you using? Some kind of Arduino?
- turbostroker
Yes I use an Arduino Uno R3 controller and a shield for connections these have all the pins I need to contoll both the system and a Lcd display and a couple of pins extra.kaputnik wrote:Hi, what Mikrocontroller are you using? Some kind of Arduino?
Bo Wernersson
Bo Wernersson
- turbostroker
Now the Jeep is a Quadfuel and all systems running
Sorry the header is in Swedish, the photo is taken too a folder for our CNG advisor and the header says "A wheelie for CNG"
Bo Wernersson
Bo Wernersson
Jim K in PA
- Vehicle Year: 2005
Video!
Now you will start breaking things.
- turbostroker
I have just start breaking things, my gearbox or my NP231 broke yesterday.Jim K in PA wrote:Video!
Suddenly i got a nasty sound from some of these.
So now I must hurry up my projekt with the rebuilt AW4 and NP242 that's I have rebuild so it's now computer controlled and programmable.
That's should been able too shift gears in 3 ways depending on settings, computercontrolled, manual with gearstick and semiautomatic with switches on the steeringwheel.
All is programmed and ready also the console that's should replace the original.
Bo Wernersson
Bo Wernersson
Thats pretty neat. What is the purpose of the drill chuck?
- turbostroker
It's control the AW4 gearshift with a wire and a homemade gearshifter.SilverXJ wrote:Thats pretty neat. What is the purpose of the drill chuck?
I should not have any gearstick at all, both the NP242 and AW4 shifting are controlled electric with microcontrollers and electric motors.
And the most inexpensive slow 12v electric motor is a 12V battery screwdriver so I bought one and take the engine and gearbox from it.
Bo Wernersson
Bo Wernersson
- turbostroker
Now the AW4 is in place and working.
Also have build a new controller both for the AW4 and CNG control so its hidden in the new center consol.
Relaycard
Microcontrollercard for AW4 and CNG
Centerconsol
Relaycard
Centerconsol
Bo Wernersson
Bo Wernersson
