I wouldn't use that.gradon wrote:Here's what I was talking about:
http://cgi.ebay.com/ebaymotors/Standard ... veQ5fTools.
I am not too concerned with the rust. that should be easy enough to remove. However, after it was washed a simple spray with WD40 or Seafoam would have prevented the rust.Muad'Dib wrote:I sent the ebayer all the information i have been armed with and here is his reply:
The valve job is always done after the Ported.
The rusty spot, is only because some water was in after it was washed
and the compressed air could not take all of it.
You can clean it easily.
This not the first head i port nor rebuild.
Theres nothing to worry about.
Its hard to tell from the pics, but from what I can see, or think I see I am not liking. I would take it to your machinist and have him take a look at it for is opinion.
Since you have it apart, push a valve up to the seat and hold it there with finger pressure. Then shine a light at the valve and see if you can see any light through the port.
