Is there any specific website you guys are using to get these ratings? The reason I ask is becuase I have been messing with injectors for a few years now and have found if you look at 4 sites you'll see 4 different flows.SilverXJ wrote:Part number should be 0280156162. At 3 bar they flow 24cc/23.61 lbs. They would flow right around 25 lb @ 49psi
stock 97 4.0 injectors?
Programbo
- Vehicle Year: 1994
- Vehicle Model: XJ
Re: stock 97 4.0 injectors?
"IF IT HARMS NONE. DO WHAT THOU WILL."
TJ9999
- Vehicle Year: 2004
- Vehicle Model: TJ
Would be interested in a website with calculations too.
In the meantime I found out: exact specs are 49.2 psi ± 5 psi for 97-04, and 58 psi ± 2 psi for 05 and 06 models.
TJ Rubicon 4.7L stroker 2004 *** Willys M201 ex french army 1957
jeepman
- Vehicle Year: 1989
- Vehicle Model: MJ
Yes they are stock which is what I believe the OP was asking about...Programbo wrote:But are'nt those just stock single port injectors? Aside from #/psi I thought one of the main reasons for an injector "upgrade" was to get the 4-port design ones for better fuel atomization/delivery.jeepman wrote:Locate the part number on the side of the injector because they have different options of injectors for example:
53030778 Fuel Injector 4.0L 87-99 (EV1 Grey 23.2Lbs@49PSI)
04854181 Fuel Injector TJ 4.0L 00-05 (EV6 Blue 19Lbs@49PSI)
I do feel that the 4 pin will be better then the single pin however I have yet to see any real data to prove one is better then the other and single pin are real easy to get in many easy to find sizes...
