looking for wide ban O2 and Gauge
Re: looking for wide ban O2 and Gauge
ftpiercecracker1 wrote:good to hear, ya the one i bought was also off of ebay for 161.99 free shipping. Was yours new or used? Because the one i bought said it was a "new, unopened item"
i am very much looking forward to getting it. BTW are you running a FPR? or just a map adjuster?
MIne was new.. and it sounds like yours was too.
I have both a FPR and MAP Adjuster. Ive found on my RENIX, adjusting MAP too far one way or the other causes cold start issues. Im still dealing with lean tip in also :(
ftpiercecracker1
Post by ftpiercecracker1 »
Muad'Dib wrote: lean tip in
Whats this? :|
Where did you get your FPR and MAP adjuster? Jeff Leigh? What did they run ya?
Didnt think a FPR was neccassary :huh: doesnt the stock system run at like 35 er 39 psi?
FlyinRyan
Post by FlyinRyan »
OP- Are you an OBDI or OBDII build?
Flyin' Ryan Performance
ftpiercecracker1
niether, Renix.
Whats this? :|
Lean tip in is usually a term used when talking to people with turbos. What it is though is basically going lean right when you press the gas to go. Im sure i can cure this with a piggyback.. just short on cash so i havent made the purchase.
lean tip in wrote:is when you boost during partial throttle, closed-loop, and the ECU tries to fight the richer ratios then stoich before it enters open-loop.
I use lean tip in to describe my problem because to me thats what it is (minus having anything to do with turbos and boost). "Lean when i tip into the accelerator."
I built my own map adjuster using readily available parts at Radioshack. Ive found on my RENIX i dont really touch the MAP voltage anymore and i only use the AFPR. Too many weird issues adjusting MAP voltage. The FPR i purchased from Jeff Leigh... but if i were to do the purchase again i would consider purchasing the Hesco one. The one i have seems to work but it has limited adjustability to bring the fuel pressure down. Bringing the fuel pressure up is no issue.
