new stroker build, some issues
Re: new stroker build, some issues
It will take a few moments for the lifter to bleed down. I would wait until it stops then take the reading.
danimal
Vehicle Year: 1991
Vehicle Make: heep
Vehicle Model: xj
Post by danimal »
but if the lifter has to bleed down for the valve to close, how is the valve actually closing at all while it's running?
It will bleed down then pretty much remain static while running. Constant pressure from the valve will keep the lifter cup in the correct location.
danimal
Vehicle Year: 1991
Vehicle Make: heep
Vehicle Model: xj
Post by danimal »
ok cool then it's probably ok. Well i guess ignition is the next step, unless anyone has a better idea.
sly-jeeper
Vehicle Year: 1994
Post by sly-jeeper »
did you check pre load on all cylinders? its most likely not fuel related if running rich didn't change it, how many miles are on it? did you break in the cam properly? im almost positive its either valvetrain or ignition
danimal
Vehicle Year: 1991
Vehicle Make: heep
Vehicle Model: xj
Post by danimal »
no i didnt. it got dark out before i could, i only checked a few. There's about 15 miles on it maybe? drove it across town to use the smoke machine. Yes i broke the cam in properly.
I'll check all the preload tomorrow i guess.
Thanks for the help guys!
I would not rule out fuel related issues yet. The PCM can do funny things if the fuel injectors don't agree with it or with the engine needs. If you have a known good set of stock ones it wouldn't hurt to throw them in a drive it gently to rule out the injectors. Salvage yard injectors always scare me also. Also, check your fuel pressure.
But as said, check preload on every cylinder. Remember it may take more time than a few seconds for the lifters to bleed down.
sly-jeeper
Vehicle Year: 1994
yea jeep pcm's are something of there own kinda like women...and idk about you but it's colder than a well diggers ass here
danimal
Vehicle Year: 1991
Vehicle Make: heep
Vehicle Model: xj
Post by danimal »
well ill consider swapping out the injectors if it continues. tomorrow i will check preload and the ignition system. might grab a distributor from the jy and a spare injector if the truck i got them from is still there.
danimal
Vehicle Year: 1991
Vehicle Make: heep
Vehicle Model: xj
Post by danimal »
sly-jeeper wrote:yea jeep pcm's are something of there own kinda like women...and idk about you but it's colder than a well diggers ass here
thankfully it's in the 70's or 80's here lately so working on the heep hasnt been too bad.
sly-jeeper
Vehicle Year: 1994
I would have a heat stroke! I just did a motor swap on a IH h tractor today and it was -5 f in my garage
sly-jeeper wrote:and idk about you but it's colder than a well diggers ass here
Yeah.. it was -10 here this morning and got to a scorching 15* max during the day... no way in hell I would be doing any engine work in that weather.
Post by Flash »
Even though you have index the dist, you my need to grind the ear of the dist so that you can fin tune the timing. (twist it back and forth slightly)
I don't know what year 4.0L you have, but my old Renix(89) ran much better after i did this.
6TIME
Vehicle Year: 1993
Vehicle Make: JEEP
Vehicle Model: CHEROKEE
Post by 6TIME »
Ditto on checking your lifter preload. Do you know how far you sunk the valves into the head? If you took .035" off the deck and then took more from the valve seat to increase spring install ht., this combination of things makes your pushrods act much longer (assuming you used stock ones?). This could possibly be maxing your lifter preload out, holding the valves open while it's running.
the grey ghost
Stroker Displacement: 4.611
Vehicle Model: comanche
Post by the grey ghost »
Could have two spark plug wires switched on the distributor, check 2 and 4, I did this once and kicked myself later
