Oh yeah.. I used Joe Gibbs 10w30 with the last Isky cam with the same result.Exos wrote: Still, I wonder if it might be a factor, especially for a new build with tight clearances. All the service manuals call for 10W30. I don't see why it should be thicker for breakin. Anyway, just thinking out loud here.
Different block, new cam, same grind though, different oil pump, different lifters, different bearings, different Break in oil.lafrad wrote:What are the consistent things across all these ranges of failures? what parts are the same for each cam failure?
The oil pickup changed when I went with the first Isky cam. Head, rockers, pushrods, crankshaft and pistons stayed the same. The rockers have been used on all the engines, maybe 4 different variations since before I built this one. This is the only time I had a cam bearing failure. It is not the rockers bleeding down oil pressure as my machinist thinks.
Since the oil pickup came out so easily from the oil pump I think the pump could have been drawing air thought the mating surface. It would also explain why when the engine got fully heated up that the weird lifter sound went away a bit. But when why aren't the other bearings showing so much wear?Bodo wrote:really looks like lack of oil to the bearings.
i have ruled out any kind of binding, so it has to be something with oil pressure/airation, or my harmonic/balance theory.
