Superchargers?
CobraMarty
- BANNED
Re: Superchargers?
Comparing the power of the new 'state of the art' engines to an engine of 20 years old technology, really? I would hope that in 20 years they would be more efficent with higher outputs and economy. As far as stroker vs supercharger there will always be debate. There is a whole website with strokers that have problems. Sure not all but many. To install a well designed supercharger in 1 day and to have output of 275/300 is quite decent. $4k for the SC vs. the stroker costs with installation and time, is about a wash. Dyno curves of each would really be impressive. An engine conversion would be even more expensive. That is why we are all different.
99 XJ M62 S/C
99 XJ M62 S/C
- Plechtan
- Vehicle Model: Comanche
Re: Superchargers?
Sorry i didn't realize i broke the rules. I am looking strictly at dollars per hp, all options. Some people need their vehicle for a daily driver and don't mind spending 4K or so for a turbo/supercharger. One day seems a little aggressive for a complete install. Many people build their stroker from a core motor, then swap the stock motor out for the storker over a weekend, or even in 1 day. If you look at the thread "how much did you spend on your stroker?" the survey shows it is generally less than $3,000.00. So if a blown 4.0 is similar performance to a Stroker, i guess i would save a grand and go with a stroker.
The name of the category is " Stroker Performance and tech" So you are correct the performance of current generation motors has nothing to do with Strokers. Neither does supercharging a 4.0 .
They are relevant for comparison purposes. If you are building a Stroker you should understand what you are doing and how it relates to the other options available. The Jeep engine started life in 1966 as the Rambler 199 cid inline 6, that makes the design more like 40 years old. The engine has several major limitations, the crank harmonic, small cam diameter, lack of 7 cam bearings, a non cross flow head, etc.
I agree that you will never be able to achieve the performance (or gas mileage) of the newer generation engines on the Jeep inline 6 platform. If you want big HP i think a supercharger is the way to go. I just don't think it is worth the effort unless you are shooting for 350-400hp.
Peter Lechtanski
ftpiercecracker1
Re: Superchargers?
sorry, this is probably a major thread highjack
, but i cant seem to find anybody with an answer.
at least it pertains to forced induction. . .
either way heres the short and sweet, turbo charged stroker.
I will be using megasquirt to handle electronics, BUT I dont know if megasquirt is compatable with a 1990 RENIX ECU.
it has two independent plugs and uses tiny metal stems instead of flat metal tabs(these are what is sticking out of the ECU plug ports).
the truck has all the needed sensors (knock, O2, intake temp, coolant temp, crank sensor, the works) I just dont know whether to get the MS1,MS2, MS3 or if I will have to make a custom plug.
again sorry about the highjack
- Muad'Dib
Re: Superchargers?
You already have a thread for this:
http://www.jeepstrokers.com/forum/viewt ... f=5&t=3252
Please keep your questions in one thread.. thanks
ftpiercecracker1
Re: Superchargers?
that would be my bad, I completely forgot about the thread i had already started.
