Good bye coil rail.
Re: Good bye coil rail.
Someone has to.
Moncheche
I just installed a coil from a 2000 viper and the wires from a 3.3L caravan. Runs like a top. My old rail kept crapping out when it got warm. One of the best and easiest mods ever.
3losh07
- Vehicle Model: tj
jeepers which one is the right number for viper coil
UF412 or UF305
or both should work fine ? without damaging pcm ?
and what was your ideas of extending the length of connector ?
and if anyone has wires number that would be appreciated .
thanks
UF412 or UF305
thanks
- darkcorp
- Vehicle Year: 1999
- Vehicle Make: JEEP
- Vehicle Model: GCh 4.0
I use Coil Airtex 5C1432. Runs good.3losh07 wrote:jeepers which one is the right number for viper coil
UF412 or UF305
Just cut wires and extend them using solder.3losh07 wrote: and what was your ideas of extending the length of connector ?
Depends on year 1999 or past.3losh07 wrote:and if anyone has wires number that would be appreciated .
thanks
Numbers for what?3losh07 wrote:and if anyone has wires number that would be appreciated .
3losh07
- Vehicle Model: tj
darkcorp wrote:I use Coil Airtex 5C1432. Runs good.3losh07 wrote:jeepers which one is the right number for viper coil
UF412 or UF305
thanks
Acutely i want to use a genuine coil instead of aftermarket
And my jeep is tj model 2000
Btw how does it work ? Worth to try ?
3losh07
- Vehicle Model: tj
Part# of igintion wire , i feel like i would screw it up if i bought cut to lenght wiresSilverXJ wrote:Numbers for what?3losh07 wrote:and if anyone has wires number that would be appreciated .
- darkcorp
I run wires Tesla T139B from CHRYSLER GRAND VOYAGER III (GS).
Retlaw01XJ
- Vehicle Year: 2001
You can mount the coil on the firewall, no wiring extensions required!
I made a z-shaped bracket to mount the coil about 1" from the firewall to clear stuff. It uses existing firewall studs.
Walt K
Eastern Pa
Eastern Pa
jeepxj3
- Vehicle Model: xj
You can use stock XJ plug wires with this?Retlaw01XJ wrote:You can mount the coil on the firewall, no wiring extensions required!
Retlaw01XJ
I mean the plug for the coil rail (from wiring harness) will reach the replacement coil (on firewall) without having to lengthen the wiring harness wires.jeepxj3 wrote:
I bought a universal spark plug wire set and cut each wire to length. My 2001 never had spark plug wires, no idea if an older XJ set will work.
Walt K
Eastern Pa
Eastern Pa
motomick76
- Stroker Displacement: 4.0
SilverXJ,
I have been spending extensive amount of time researching this, and want to thank you for your ingenuity on this. One last question before I pull the trigger on this, you have a 2000 XJ and I have a 2000 TJ. The connector from the wire harness to coil for your setup is straight-through, just extended. Then there is the 180 'flip' for some people. Who needs the flip, and who needs the straight-through? Are the XJ and TJ wired same?
Thanks again.
Thanks again.
3losh07
- Vehicle Model: tj
I need help
I have bought and installed viper igntion coil part# uf412 -B2918M
And jegs performance wires 40219 and i did the same as you guys installing 1&6 at the bottom, 2&5 middle and both flipped and non flipped 4&3 at top
The engine started but not smoothly
The problem here there is a lot if vibration that shake the car body with it and i have no clue what is the reason
Could be the wrong coil ? Or wrong wire ? Or bad pcm ?
It Can not be the spark plugs because i reused the coil rail and the engine started without problem
My jeep is 2000 tj 4.0l
- darkcorp
I would check by disconnecting spark plugs one by one and finding therefore those that are wrong connected.
As far as I know the 99 WJ is the only one that needs the wires switched.motomick76 wrote:SilverXJ,
Thanks again.
