Show your stuff...
Maddawg
Vehicle Model: G.Cherokee
Re: Show your stuff...
Post by Maddawg »
Silver, did you add the hood air dams yourself?
2000 Grand Cherokee 4.6
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
Maddawg wrote:Silver, did you add the hood air dams yourself?
Yes.. making that first cut was a real bitch.
Maddawg
Post by Maddawg »
Probly as bad as the first cut for sunroof .....lol. looks great for sure
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
Actually, no not that bad.. I can easily replace a hood... a roof.. not so easy.
1bolt
Post by 1bolt »
That's one clean well done XJ, digging the monochromatic vibe
Simon
Ground up YJ build.
93 block/head
.080 with Diamond pistons. .042 quench 9.56:1
Eagle rods spinning a 12wt crank
Roller rockers
Hesco 274/480 stick
01 intake with a 64mm TB
Balanced
Ported
Edlebrock header with Dynomax SS exhaust
NV4500/Atlas
5.13`s with Detroit's
HP44/8.8 chromo`s CTM`s girdled, trussed
Hydroboost
PSC steering
etc etc
79 CJ5 and 03 TJ
A couple more pics...
jsawduste wrote: Image
I like blue, but damn that is a lot of blue. What is that brass thing near the throttle cable?
Thanks for the kind words.
Still need to clean up the wiring by the battery. Redid the harness and have to integrate some accessory wiring.
The brass cannister is actually the diaphragm for the mechanical fuel pressure gage... RIP. Will be updating to an electric model soon.
If you are going to be doing work on the battery wiring I would suggest these terminals
They go by military battery terminals and can be had at Napa. They do a better job than the standard strap type. And you have 4 different spots you can tie accessory cables in to. Plus they are silver in color which matches blue better than brass.
Thanks Silver, I`ll look into them.
Kinda anal on electrical systems. IMHO Jeep did a crappy job of power distribution and grounds.
I have already completely rebuilt my rear and dash harnesses. Adding better connectors and additional grounds. Plus changes in wire gage.
Over the winter the engine and front harness will be rebuilt. Integrating some of the loose wiring you see next to the battery into one clean package.
Mounted on the firewall just under the dash is a 6 circuit fuse box. All of the "extra" electrical accessories run off that added box. Radio, CB, aux. power plug, etc. Totally separate from the factory harness.
I can't stand the $#!++! stock terminals nor the cheap replacements I used that fail to get the - tight enough--I'm way overdue for good quality terminals and the 2 gauge welding cable upgrade(and headlight harness as well)!
Try "Weatherpack" connectors. They are made for/by Delphi and are OEM for GM cars/trucks.
eBay has several kits or you can buy them piecemeal. HiPo automotive is one seller that works well. :cheers:
Jeep4xb4u
Vehicle Make: XJ 2dr
Vehicle Model: Sport
Post by Jeep4xb4u »
So hears my pile that the stroker and the D44 is slated for. Obviously there is an endless list of ongoing projects but you get the point.
88' XJ 2dr
4.0l / AW4 / NP231 / D35c
