my long drawn out street/strip xj build
- vashxj
- Vehicle Year: 1999
- Vehicle Model: cherokee
Re: my long drawn out street/strip xj build
Actually I did already and it got better but still not perfect
- vashxj
Forgot to post I got to the dyno finally. And it came out to be 285hp and 348ftlb
https://youtu.be/6YBFPWerGFQ
Blew out a seal or something in the trans over the weekend so she is grounded for the rest of the year but thats ok I have already started collecting parts for this winters upgrades
At the wheels!!! Damn nice!
- vashxj
so because of idea changes ill give first notice to this forum before I post it on other ones and craigslist. I am selling my s/c setup this would include the vortech v1 unit, the 3.33 pulley it came with, the 2.5 pulley I bought, oil and return lines, the 6 rib belt I had on it, idler pulley, custom bracket to fit 4.0L, and 42lb injectors. all you would have to do is remove your a/c and bracket get some electric fans and bolt this up, tighten the belt, install injectors, and just figure out the piping. (I would recommend a intercooler) get a tune and you have about 80hp-80ftlb more at 5 psi. only problem is I was having some belt slip under high rpms and this unit is really only good to about 8psi. I just want a lot more power otherwise this setup has been great drove over 1500 miles on the power tour with it. im asking for $1600 +shipping. vortech units are 2000+ new, not to mention all the custom stuff to put it on your 4.0 is right here
- vashxj
- vashxj
asking 1200 for the s/c setup and also selling my nitrous kit with bored through tb and tb spacer that's tapped for n2o nozzle for 500 its a zex 125 wet shot. 1 zex bottle and 2 nos bottles. have jets for 75 and 125. kit is zex 82026
- vashxj
alright not selling my setup anymore. decided to perfect it, so new pics soon. currently getting all new suspension front and rear, cobra lsd, bigger wj brakes, removing abs, adjustable proportioning valve, relocating battery, separating s/c belt, intercooler, cleaning up wire harness a little and I haven't touched them since high school (9 years) but all new kicker speaker and a nice 10in pioneer built into the back wall. no more stupid big sub box...... I must be getting older lol
If you search for a post I did on NAXJA I give part numbers for a basically bolt in prop valve to replace the stock combo valve.
I saw one of those sub boxes that go in the right rear fender for sale recently and I was going to buy it.. but then I forgot that I have air pumps there.
- vashxj
ya its kinda nice and its for a 10", that plastic pod they make is only available in 8". I actually already ordered a nice adjustable one from summit. once I get these stupid control arm and leaf bolts out things will start going faster. I have never removed the bolts that go into the frame on those so at 216k mi they are rusted in the bushing sleeve.
