Gorilla's XJ quest for the 4.6L....
Posted: February 26th, 2012, 8:38 am
				Hello there! I am very into rock crawling and out doors, I got my Cherokee about 4 years ago and stove it in stock form for about 3 1/2 years. then I decided it was going to be my next project.. On went the lift, swapped axles, changed the whole suspension, lockers ect ect... all my jeep info is here...  http://www.cherokeeforum.com/f46/my-2000-xj-67081/
A few pics for fun...
Well, My head cracked... damn 0331 head. So a buddy hooked me up with a 7120 head. I also ended up getting a deal on a 4.2l crank, rods, Comp Cams 68-232-4 4X4 performance Cam, lifters, Timing set for 200$
So here goes the Stroker! Going to stroke the 4.0L to 4.6L.
Parts list-
258 crankshaft: 4.2L light weight short nose crank 20$(Check)
Connecting rods: 4.2L Rods 20$(Check)
Cylinder Head: 7120(Check)
Pistons & rings: Sealed Power H825CP 35$ each w/rings .20 over (Check)
Main bearings: Clevite $60(Check)
Rod bearings: Clevite $45(Check)
Cam bearings: Clevite $25(Check)
Oil pumps: Summit Racing (I am using high volume) (Went with Mopar $55 dealer cost)(Check)
Timing sets: Summit Racing (have Comp cams kit, cost me $30) (Check)
Camshaft & lifter kits: Summit Racing (I have Comp Cams 68-232-4 4X4 cam w/lifters $130)(Check)
Cam bolt, pin & spring: Hesco (to be able to install a 96 and older cam into a 2000 Block) $15 (Check)
Cam bolt washer: Hesco $6(Check)
Rocker arms: Going with "performance set" http://www.hescosc.com/shop.asp?action= ... 5&catId=77 58 $150(Check)
Mopar Performance 5249464 valve springs: Summit Racing ($88 Dealer cost) (Check)
Mopar Performance 4452032 valve spring retainers: Summit Racing ($90 Dealer cost) (Check)
Mopar Performance 4529218 valve keepers: Summit Racing ($25 dealer cost)(Check)
Pushrods: Reuse stock 4.0, Hesco (I got upgraded rods with thicker tubing, stronger for upgraded cam/springs) $42 (Check)
Gaskets & seals: Summit Racing, Mopar Performance (I am using Mopar performance) $145 (dealer discount) (Check)
Head Gasket: Mopar Performance 0.43" compressed height (stock is 0.51) (Included in Mopar performance kit)(Check)
Flowkooler high flow water pump: Summit Racing $110(Check)
Thermostats: Summit Racing (went with High flow) $12(Check)
High flow thermostat housing: Hesco $28(Check)
Using Stock Cylinder head bolts $45(Check)
Machining crank/rods and pressing pistons - $165(Check)
Port and Polishing head - 20$ kit (Doing it myself)(Check)
Three angle valve grind on valves and head - 65$(Check)
Ford 24lb Injectors (already had them, $50)(Check)
APN manifold (for 91-99 to fit 7120 head)(Check)
Exhaust wrap for manifold (keep intake temps down)(Check)
60mm Throttle body ($55)(Check)
(I am doing all the assembly)
My total cost will end up being about $1800 after all misc stuff... I also plan on getting a wide band 02 sensor, buy wont be able to afford it right away. so I'll run premium until I can monitor it.
Some pice of the parts....
wrapped manifold to help lower the intake temps.
Bored TB to 60mm straight threw....
High volume T/stat housing
High flow W/P
High Volume oil pump
Mopar gasket kit
Mopar valve springs
Hesco "performance" valve rocker kit.... (couldn't justify the $$$ for rollers at this time, maybe later once I've recovered financially)
rocker vs rocker
And all of it... with new coolant temp sensor/crank pulley dampener and a few other non listed items...
Taken from the calculator on this site...
Bore - 3.895
Stroke - 3.895 (making it square)
7120 head (shaved 0.10" to make flat) lost about 1.3cc per chamber making it 56.6 correct?
Keeping stock deck clearance .0215" correct? (doesn't change with stroker setup)
Headgasket 0.051"
Pistons 15.8cc Sealed Power.
Cam duration 250
Cam separation 113
Cam Deg advanced 3*
Resulting with-
SCR of 9.74-1
DCR 8.37-1
Quench 0.0725"
Just waiting on the machine shop to finish the 3 angle valve grind, then I'll pull my motor and get it going... Hopefully It will all work out smoothly and run good for me...
Parts list-
High flow W/P
Mopar gasket kit
Mopar valve springs
rocker vs rocker
Bore - 3.895
Headgasket 0.051"
Cam duration 250
Cam separation 113
Cam Deg advanced 3*
Resulting with-
SCR of 9.74-1
DCR 8.37-1
Quench 0.0725"
