how to tell if you have a stroker?
Posted: May 18th, 2012, 5:48 pm
i have some questions for you fellas and i hope you can help me figure out what my jeeps got under the hood.
side note: i write a lot
----history-----
traded lifted cherokee straight across for this jeep to college kid from houston. he wasn't a mechanic and this is an old wrangler, carb'd. he wanted fuel injection and the lifted look while i wanted a wrangler with 6 cylinder, auto, hardtop and full doors. it was a swap made in heaven
. the wrangler had some little issues which i recognized as soon as i popped hte hood on it when we met to swap. the cherokee was perfect but i was ok with it because it was the carb and linkage system that was causing this guy's troubles. we swapped and i drove it home from victoria, roughly 2 hours with no trouble. the kid tells me afterwards "the jeep has had some work done on it. the previous owner swapped the block and did some work but i don't remember what it was." hmmm, i wonder what.
the carb was a crappy weber 34 two barrel. it ran ok but dieseled like crazy when you turned it off. no matter what i did, i couldn't get it to stop. and the jeep got terrible gas mileage, 10-11mpg. the dieseling really bothered me so onto craigslist i go and find a stock chrysler two barrel holley from a 68 something with a 340 or 360 v8 for 20 bucks, SCORE!!! i rebuild it and drop it on and what an improvement. the jeep is badass. can smoke a tire once in a while and runs down the highway up to 100mph like nothing. i am living the good life.
but, life moves on and the good life becomes normal and things i didn;t notice in my joy to have a non-dieseling jeep start to pop up. gas mileage has not improved one bit and hte jeep idles terribly rich. i learn about vacuum gauges at this point and tune up the carb. runs great but i realize i can do better so i start with the gauge and screwdriver and a mixture screw snaps off jaggedly.
dammit, what the heck?!
i pull the holley and throw on a motorcraft 2100 and it is back to running. not as good as with the holley but ok. dang it, for some reason, i have lost a huge amount of power and have to floor it to keep highway speeds. gas mileage has increased though. i cannot stand the lack of power so the motorcraft comes off and the intake comes off for an offenhauser intake i got off ebay cheap. motorcraft goes back on and nothing has changed. dammit!!
i start researching jeep mods and learn that the reason nothing fits when i buy 87 parts is i have a 99 block in my wrangler. why the hell would someone put a 4.0 block in a jeep under a 4.2 head? is something done to this jeep i don;t know of?
after the intake swap and reading a lot, and discussion with fellow jeepers on other forums, we have come to the possible conclusion my jeep has been stroked.
how you ask? well, let me list the ways.
4.0 block
4.2 head
old school distributor with 13/18 advance plate
jeep smokes the tires when i have 225/75/16 tires on it, larger then stock!!
previous previous owner mentioning to previous owner engine work and block swap
jeep smokes tires with oversized tires on it
jeep is a light to light dragster (for a jeep)
jeep smokes tires
i am running the offenhauser intake and a holley 4 barrel currently. i just put 31" tires on a few days ago. it cruises on the highway like nothing and can pass people with ease. i know the 4.2 isn't known for doing that kind of stuff.
what can i look at, without tearing the engine down, to see if i have a stroker or not. everyone tells me i do and i will happily believe them but i have this back of my mind voice saying "you cannot verify that so stop saying it is."
give me some ideas fellas.
here is the monster, on the previous rims and tires
----history-----
4.0 block
4.2 head
jeep smokes tires
