				What to do with old 4.0 crankshaft
				Posted: September 8th, 2008, 9:12 pm
				by seanyb505
				Well now that the stroker is running, I have spare crankshaft sitting in the middle of my floor. Im using the old rods and pistons as book ends and the old timing set as a clock, I was hoping someone could come up with a similar use for the crankshaft. Im thinking lamp but can you guys think of anything else? I dont want to just throw it away, I feel like I would be throwing away part of the Jeep's heart and soul
				Re: What to do with old 4.0 crankshaft
				Posted: September 9th, 2008, 5:38 am
				Picture of timing set clock?
				Posted: September 9th, 2008, 6:57 am
				by seanyb505
				Well I dont have it yet, but I know it will be fairly easy if you go to the right stores. Check this site:
www.stevenshaver.com He has more timing set clocks than he knows what to do with. So he sells them for exorbitant amounts of money.
				Posted: September 9th, 2008, 3:56 pm
				by amcinstaller
				use the crank and an old disc brake rotor for a trouble light stand. thats my plan so far. twin 150W halogens should make things easy to see
				Posted: September 25th, 2008, 7:42 pm
				by Alex22
				I'm sending mine off to the crank grinder to keep as a core.  If he doesn't want it then it will probably become a boat anchor, door stop, toe stuber lamp or weight in the back bed of a friends truck for the winter.
~Alex
				Posted: September 26th, 2008, 6:47 am
				by seanyb505
				Boat anchor is a good idea, but I dont have a boat. I tihnk Ill end up going with the lamp. I just need to find a way to not have the cord hang down all sloppily.
				Posted: December 11th, 2008, 11:59 am
				by Flash
				Bolt a old flywheel on it, stand it on end, and attach a mail box
Flash
				Posted: February 21st, 2009, 2:45 am
				by 5-90
				Or use an old flywheel for a foot, make a nice metal tray for the top, attach it with the nose screw, and you've got a fun (and potentially very useful) heavyweight occasional table for use out in the shop!
				Posted: February 21st, 2009, 7:21 am
				by yuppiexj
				make a lamp out of it, route the wire through the oiling holes in the journals.
Would need a nice wide base, an old flywheel seems to be a popular choice, or attach it to an end table.
