4.7 stroker consistently runs hot
Posted: February 16th, 2017, 1:46 pm
				I've been having issues keeping my newly built 4.7 stroker within the normal temperature range. I've read dozens of threads both on this forum and others but haven't found anything that seems to be the problem for me. My jeep is a 1995 Cherokee (OBD1)
For starters, everything in the cooling system is brand new within the last year with the exception of the heater core which is original. When I first got the jeep it had a cracked radiator so I replaced it with a Spectre aluminum 3 core radiator from Napa along with a new 16 psi cap and 195 degree thermostat. This setup ran fine for the year or so that I had the old motor in for. Temps never reached above 215 even during the summer.
Fast forward to now, my new stroker has been in and running for a little over a month now. Once it's warmed up, the lowest temp it will ever cycle to is 215 and that's a rarity. Usually it runs from about 220-240 or so. When I put the motor in I reinstalled my 1 y/o T-stat because it tested to be good still. I just decided to change it out this week for a new one (tested good). I also checked the 1 y/o one again and it had gone bad in the 250 miles I put on it so far. Still made no difference in temps between the two thermostats. Both were 195* thermostats.
Currently my cooling system is as follows:
Spectre 3 core radiator (1 y/o)
16 psi cap (1 y/o)
195* thermostat (new)
Flow Kooler high flow water pump (new)
Upper rad. hose (new)
Lower rad. hose (new)
Heater hoses (new)
Heater control valve (new)
Stock mechanical fan (age unknown but in great condition)
Stock e-fan (original; currently not functioning due to PCM short; but when wired straight to battery has no effect on ECT's)
Block and head were both hot tanked while apart
No cooling system leaks
Serpentine belt (new, not slipping)
Coolant temp sensor for PCM (new)
Coolant temp sender for gauge (new)
I'm pretty stumped by this. I even flushed the system out a couple times including the heater core and the radiator to little advantage. Any ideas? Suggestions? I'm going to be ordering a new PCM soon so I will have a functioning E fan again but it had no effect on the coolant temps when I wired it straight to the battery for testing.
Any help is appreciated.
-Mason
16 psi cap (1 y/o)
Heater hoses (new)
-Mason
