fuel injector ?
Posted: April 4th, 2017, 10:14 pm
				I have aem neo. Had to add 14 to get afr correct. But the aem is changing vacume reading in computer causing timing to be either advanced or retarded not sure. But I think I need to go bigger on injectors to lower how much im having to add on the neo. To bring timing back to working parameters. What do you all think. Right now running 24# ford. Changing to 30# bosch. At around 45# fuel pressure
