Injector problems?
Posted: August 16th, 2017, 8:46 pm
				Background:
Originally with this new stroker engine (and Hesco 1995 OBD I MPI), I had bought from eBay InjectorPlanet Bosch Fuel Injectors 0280155849 (rated 24.5lb/hr @ 43.5psi same as Ford XF1E-A5B), but I couldn't get the engine originally to catch... at first I was flooding the engine, then it appeared I was starving the engine.
So I put the original 1995 Hesco MPI injectors with my adjustable fuel pressure regulator cranked up as high as it would go.... no luck.
Then I put a new CPS on and it started right away with the 1995 Hesco MPI injectors and the Hesco Adjustable Fuel Pressure Regulator cranked up all the way.
This has been working for about the first 200 miles on the new engine.
Then the new fuel pump started to whine loudly and surge/de-surge a bit yesterday.
- So tonight, I thought I'd experiment with Bosch Fuel Injector 0280155849 injectors I tried earlier.
- It ran rough at first for a few seconds then evened out some, but then at idle, the engine would race at idle at 2200 rpm Throttle was very touchy.
- Then I drove it around the block (2200 rpm idle or 1400-1500 rpm idling in 1st gear) thinking the computer needed more time to learn, but that didn't help.
- I brought it back and saw I had code 52 (bad O2 or too high fuel pressure at rail). So I disconnected the battery for a few minutes to clear the computer codes thinking it needed to re-learn from OEM settings.
- Then drove it around the block again.... same 2200 rpm idle (or 1400-1500 rpm idling in 1st gear) and then the MIL light stayed on.
- Came back and lowered the fuel pressure a few turns (for some reason my fuel rail schrader valve has stopped working) and now it won't start.
- Cranked it back up again and still no start.
- I have spark going to the distributor.
So I tried testing fuel: I get about 1/8+ cup of fuel (about 3 tablespoons) at fuel supply line when disconnected from fuel rail (with one Key On Engine Off).
I'm going to try tracking down a fuel pressure tester tomorrow.
Question: Can fuel injectors be finicky and alternate between being stuck open and stuck closed?
Is it possible I got one or more bad injectors?
Other thoughts?
   Throttle was very touchy.- Then I drove it around the block (2200 rpm idle or 1400-1500 rpm idling in 1st gear) thinking the computer needed more time to learn, but that didn't help.
Other thoughts?
