				STOCK FPR OR ADJUSTABLE ??!Hey guys
				Posted: December 16th, 2019, 9:31 am
				by shifo
				Hey guys
I finally built my 94 yj stroker. Except I have a little problem. The fuel to air ratio is not good at idle and slow speed.
I was wondering which is better to fix this problem. To use adjustable fpr or map sensor ?? And which FPR to use??
Here is my stroker details.
4.2 crank
4.2 rods
.040 pistons
Comp cams cam 235-4
Rollmaster chain
Mopar performance springs
24lb 6 holes injectors
Stock head
2000 models intake
Throttle body spacer
I appreciate your help.
				Re: STOCK FPR OR ADJUSTABLE ??!Hey guys
				Posted: December 16th, 2019, 10:16 am
				by Cummins90
				What is your AFR?
				Posted: December 16th, 2019, 4:21 pm
				by SkylinesSuck
				And what part number are your injectors?
				Posted: December 17th, 2019, 4:22 am
				by shifo
				I don't know what is the AFR. How do I know it ?
And the injectors are the ford 24lb (M-9593-LU24A)
				Posted: December 17th, 2019, 11:57 am
				by Cheromaniac
				Your injectors are appropriate for your application but when you say "The fuel to air ratio is not good at idle and slow speed", is it too rich or too lean? What about when accelerating and when cruising? How are you measuring the air:fuel ratio?
				Posted: December 17th, 2019, 12:53 pm
				by shifo
				I said that because when i speed the engine seems to be fine but in low speeds or idle its very weak and stumble. Some times there is black smoke when am warming the car in the morning.
So for my application do I need adjustable FPR at all. Or my problem is unrelated ?
				Posted: December 17th, 2019, 11:18 pm
				by Cheromaniac
				You could have a bad upstream O2 sensor.
				Posted: December 19th, 2019, 12:33 am
				by shifo
				I just installed a new one (bosch) and there is no error codes on the computer at all.
				Posted: December 21st, 2019, 5:56 pm
				by SkylinesSuck
				Get a wide band O2 sensor. All of this is pointless without actually knowing what your AFR's are.
				Posted: December 23rd, 2019, 6:10 am
				by shifo
				And how do I actually know the AFRafter I get that o2 sensor ?
				Posted: December 23rd, 2019, 12:13 pm
				by Cummins90
				https://www.summitracing.com/parts/avm- ... gKcrvD_BwE
It is a kit you install and is self calibrating. You will need to weld in the provided bung.
