Page 1 of 3
				Over heating. Help!!
				Posted: July 28th, 2020, 7:55 pm
				by Xtultegra
				Fresh 4.6 build. Will run all day in stop and go traffic or idling up some knarly trail in 110 degree weather and never go over 195. Pull a hill on the highway or travel down the highway at 3000 rpm and it will over heat in about 5 minutes.  Temp comes down if I slow down.
What I have done: new flow cooler water pump, high flow 194 thermostat, new double row aluminum radiator, new CPS, flushed the holy hell out of the system with Red Devil Flush (3 times), added wetting agent, running 60/40 water to coolant ratio.
Engine sounds great. Pulls like a beast. No stutters, backfires or misses. However, it idles past 12 degrees advanced, more like 20 degrees.
				Re: Over heating. Help!!
				Posted: July 29th, 2020, 7:52 am
				by KarmaKannon1
				Have you tried backing the timing down(not even sure it's possible without a crank sensor mod)? I've never had the issue, but I've heard friends have to back their timing down because at speed they would run hot. I don't actually know the base timing for a 4.0 is. I'm guessing it can't be more than 15* btdc.
Clogged exhaust, transmission issues, and coolant cavitation would be some other things I'd be looking at.
				Posted: July 31st, 2020, 7:53 pm
				by RubiMikeTX
				Are you still running the stock, original mechanical fan-clutch? If so, replace it.
				Posted: August 29th, 2020, 12:37 pm
				by Russ Pottenger
				Any updates?
				Posted: September 3rd, 2020, 8:50 am
				by dwg86
				Possibly running lean? what size fuel injectors are you running?
				Posted: September 20th, 2020, 11:58 am
				by Bertismyname
				More than once I have seen the wrong water pump installed. Be sure that it is the correct rotation for your engine. The wrong rotation will cool a little bit. But, at higher loads and engine speeds it quickly over heats.
				Posted: September 22nd, 2020, 7:16 am
				by SkylinesSuck
				KarmaKannon1 wrote: ↑July 29th, 2020, 7:52 am
It is not possible, at least how you are thinking.  And retarding timing increases temps, not decrease.
				Posted: November 18th, 2020, 8:28 pm
				by Xtultegra
New header, exhaust, cat, straight flow muffler.
				Posted: November 18th, 2020, 8:30 pm
				by Xtultegra
				RubiMikeTX wrote: ↑July 31st, 2020, 7:53 pm
Tried stock fan and two electric fans with shroud.  Electric fans worked better, but still can't go freeway speeds without overheating.
				Posted: November 18th, 2020, 8:41 pm
				by Xtultegra
				dwg86 wrote: ↑September 3rd, 2020, 8:50 am
 Bosch flow rates @ 43.5 psi / 3 bar24.7 lb
				Posted: November 18th, 2020, 8:42 pm
				by Xtultegra
				Bertismyname wrote: ↑September 20th, 2020, 11:58 am
Used stock pump, then tried high flow. No difference.
				Posted: November 18th, 2020, 8:45 pm
				by Xtultegra
Barely stays at 220 going 3000 rpm down freeway in 60 degree weather.  Have been thinking about trying an oil cooler or maybe one big electric fan instead of the two smaller.  Fan doesn't seem likely problem as I'm doing 65 down the freeway.  Tried removing lights and winch but didn't help.  Maybe my ecu is bad. Everything works great. Just over heat at high rpm.  Jeep is nearly unusable on freeway during summer.
				Posted: November 19th, 2020, 2:25 pm
				by bnelson
				Sounds silly but have you replaced your radiator hoses? I have seen the inside of a hose tear loose and with normal flow/low RPM they seem to cool fine but with higher RPM and faster water flow the inner lining balloons up and blocks the flow of coolant. Also how old is the radiator? Water scale buildup possibly?
				Posted: November 20th, 2020, 7:33 pm
				by Xtultegra
				bnelson wrote: ↑November 19th, 2020, 2:25 pm
Yeah, started with spendy silicone hoses, but switched to oem hoses just to see if that would work.
				Posted: November 26th, 2020, 10:58 pm
				by Xtultegra
				Radiator is brand new double core oversize
