151 to 4.6 stroker build
Posted: April 15th, 2009, 12:04 am
hello all jeepers. been lurking, reading, and planning for a while on hear and other sites trying to get this stroker build up and rolling. ive decided to post my progress hear since you guys are far more nowledgeable than i am. i have a 91 xj 4.0 thats going to become a 4.6 and replace a gm 151 in my 81 cj5.
when i started researching engine swaps and realized that i have some of the main parts laying around the barn it was a no brainer( couple of 258 in the corner of the barn). ill post pics of some of the things ive come up with so far. i had pics of the engine as i took it apart but i moved a box to the ground that contained engine harness and camera and my stepfathers dogs got ahold of the camera. so ill get some pics of the block and head tomorrow.this is what i plan so far not everythings rock solid(just what ive purchased so far).
91 4.0 complete engine (purchased)
92 wiring harness from a manual(purchased)
4 weight crank that needs to be turned(already had)
4.2 rods casting number 707 should be back soon(already had)
sealed power 677cp30 dished to 23cc(falcon)
comp cams 68-231-4(need)
clevite bearings (falcon)
diy port and polished head 3 angle valve job checked for flat(need)
valveterain?
timing set?
bore throttle body
header?
air filter?
and other things needed to fit it in cj(inline fuel pump,radiater,cps relocation kit,clutch,rebuild t176 and dana 300, vss, engine mounts, ect.)
.0025 deck height take off .043
gasket kit? .044 mls head gasket compressed(need)
quench of .0465 scr 9.44 and dcr 8.04
any suggestions on how high i can go with dcr and run on premium. should i deck more?
valveterain?
timing set?
bore throttle body
header?
air filter?
