Will it work? just making sure
jn2630
Learning to use the board
Vehicle Year: 1993
Post by jn2630 »
I have ordered my parts and the machine work is being done. I'm just doing a reality check, will this all work? Here is my recipe:
-Block Bored .030 over
-4.2 Crank rods and mains ground .010 under
-4.2 Rods
-New stock pistons and rings
-Ford 24lb injectors
-Cam? I need some advice
What should I expect in terms of horsepower? Will it run on regular fuel? Will I benefit from a performance cam? Please tell me if I'm missing anything. Thanks in advanced.
shockcocker04
Re: Will it work? just making sure
Post by shockcocker04 »
are you building it yourself?
jn2630
Vehicle Year: 1993
Post by jn2630 »
Yes, its my first engine build.
shockcocker04
your specs would make it a 4.6L, your cam selection has a lot to do with the reliability of your engine as cams are the known problems of strokers. running on regular gas all depends on your compression ratio. i would select your cam on the type of driving and use of the jeep.
jn2630
Vehicle Year: 1993
Post by jn2630 »
Ok, mostly my jeep will be a daily driver, and some off road, so I need a good torque curve. If I use stock head gasket, what will my compression ratio be?
shockcocker04
that depends on how much the head and block are decked, if the pistons are dished, if the combustion chamber is opened up. and the thickness of the head gasket. i cant tell you the compression ration, there are to many variables that are not decided.
jn2630
Vehicle Year: 1993
Post by jn2630 »
Lets say no material is milled off the head or block, the pistons are not dished, and the head gasket is stock.
shockcocker04
then it would be stock, you would just have more volume in the cylinder. increased compression is were you build power. if your reusing the head and block then you should have them decked to ensure perfect flatness.
RAPTORFAN85
Vehicle Year: 2001
Vehicle Model: TJ
Post by RAPTORFAN85 »
shockcocker04 wrote:then it would be stock, you would just have more volume in the cylinder. increased compression is were you build power. if your reusing the head and block then you should have them decked to ensure perfect flatness.
not true. the compression with that setup would be about 9.7 static. Much higher then stock...
"Strrrrroke me, stoke me...."
Billy Squire
shockcocker04
would it be because the pistons are not dished? 8.8 is stock right?
RAPTORFAN85
Vehicle Year: 2001
Vehicle Model: TJ
shockcocker04 wrote:would it be because the pistons are not dished? 8.8 is stock right?
It's because you have more volume in the cylinder. When the valve timing events are at the same position and the volume increases you have to compress the air more to fit it into the same sized chamber. Dishing the pistons would make the compression drop because it would put more room in the cylinder so you wouldn't have to compress the charge into such a small area, if that makes sense .
Billy Squire
shockcocker04
i understand, i got kinda turned around :doh:
jn2630
Vehicle Year: 1993
Post by jn2630 »
how much material must be removed from the head/block total to bring the compression ratio in the 9.5 range?
eastin82
Post by eastin82 »
removing material from cumbustion chamber would help(not the bottom of head) or dishing pistons you just need to play around with cr calculator!!
keepin the five alive!
jn2630
Vehicle Year: 1993
Post by jn2630 »
Ok, I've been messing with the CR calculator, but I need to know if the stock 4.0 pistons are dished already, and how much. Thanks for clearing some things up guys.
Users browsing this forum: Bing [Bot], Semrush [Bot] and 3 guests
