Motor mock up
Maddawg
Vehicle Model: G.Cherokee
Motor mock up
Post by Maddawg »
Hey all. Was wondering what the thought was of mocking up my block & head to determine my pushrod length( pistons being dished currently). Heres so far .004 deck height, .044 HG, .004 shaved off head(need to double check that with shop). This way I could order rockers & rods for assembly this weekend.
Thanks Dale
2000 Grand Cherokee 4.6
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
eastin82
Re: Motor mock up
Post by eastin82 »
i would get ahold of silverxj on this forum and rent a checking pushrod. thats my plans anyway
keepin the five alive!
Maddawg
Re: Motor mock up
Post by Maddawg »
I'm going to run up to Summit & buy one, was wondering about putting shims for HG, basicly a mock up (until I can fully assemble when pistons are done) so I can get rods ordered. Since I'm using standard rods & lifters I believe this should get me close enough to order them.
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
eastin82
Re: Motor mock up
Post by eastin82 »
how much are they maddawg?
Re: Motor mock up
Its always a good idea to do a mock up... Since it sounds like your in a time crunch, your idea seems fine since you cant actually put the head on yet.
If it were me i would wait untill i have the head on, and then start measuring etc.
Maddawg
Re: Motor mock up
Post by Maddawg »
Here is the link from Summit.
Trick Flow® Adjustable Pushrod Length Checkers
Pushrod Length Checker, Adjustment Range 8.500 in. to 9.800 in., Ball Ends, Each $11.95 Shipping $4.95
http://store.summitracing.com/egnsearch ... =%2D108240
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
Re: Motor mock up
The problem with those pushrod checkers is that you need some way to measure it... I don't have a caliper that larger and my machine shop didn't either. I went with this one: http://store.summitracing.com/partdetai ... CCA-7704-1 It starts out at 8.8" and each rotation equals .050".
eastin82
Re: Motor mock up
Post by eastin82 »
thats not a bad price and im sure i could get a caliper from work to measure, but not quite there yet :brickwall:
Maddawg
Re: Motor mock up
Post by Maddawg »
I was looking @ that one as well & trying to decide.
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
Re: Motor mock up
Post by dwg86 »
Use a pushrod checker. The one I bought was from comp cams. I think it went from 8.800 to 9.800. One turn equals .050. Use the measurement from the pushrod. Do not use calipers to measure the pushrod checker. Your measurement will be off. Check out this link. On measuring pushrods: http://www.trendperform.com/measuring.html
Re: Motor mock up
Also, keep in mind that there are 3 different ways to measure pushrods.
eastin82
Re: Motor mock up
Post by eastin82 »
what are the three ways silverxj?
Re: Motor mock up
Post by dwg86 »
Don't mean to jump in here, but buy a length checking pushrod and order what ever size it says you need. That is what I did and it worked. No math or guessing you are ordering the right length. Trend pushrods were the cheapest I could find, quality is excellent and fast shipping. I used a comp cams pushrod checker. Trend also sells one for the same price. It was well worth the $20.00.
Re: Motor mock up
eastin82 wrote:what are the three ways silverxj?
Maddawg
Re: Motor mock up
Post by Maddawg »
Jump in the more help the better. Ok so which of the 3 are correct? I think I'm missing something here! :doh:
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 3 guests
