pipe plug next to camshaft
StroktWJ
Vehicle Model: Grand Cher
Post by StroktWJ »
I got my 00 block back from the machine shop yesterday and noticed that the pipe plug next to the camshaft was missing, I checked my 94 block and there was a pipe plug in the hole. Is this necessary or is there a benefit to not putting a plug back in the hole? I will be running the earlier style camshaft & timing set.
#727 Crank
Clevite 3415 Pistons
91-95 Camshaft
7120 Head
00 Intake
Magnaflow Muffler
Offroad Pipe
yuppiexj
Re: pipe plug next to camshaft
Post by yuppiexj »
You need it.
There should be one on the back (flywheel) side of the block as well.
Plechtan
Post by Plechtan »
The plug is in the end of the main oil galley that feeds all the lifters and bearings in the engine. if it is not in, you will not have any oil pressure. If you follow the hole from the center of the oil filter mount, you will see it intersects this hole.
Peter Lechtanski
StroktWJ
Post by StroktWJ »
I have the pipe on the back of the block and the driverside, but not the one behind the cam gear.
#727 Crank
91-95 Camshaft
7120 Head
00 Intake
Magnaflow Muffler
Offroad Pipe
StroktWJ
Post by StroktWJ »
Plechtan wrote:The plug is in the end of the main oil galley that feeds all the lifters and bearings in the engine. if it is not in, you will not have any oil pressure. If you follow the hole from the center of the oil filter mount, you will see it intersects this hole.
That's what I was looking for! Thanks you just saved me some serious headaches!
#727 Crank
91-95 Camshaft
7120 Head
00 Intake
Magnaflow Muffler
Offroad Pipe
