stroker timing
daccarettfletez
Where's the "any" key?
Stroker Displacement: 4.5
stroker timing
Post by daccarettfletez »
Just talked to the shop they finally assembled my 4.5 stroker, but have problems with it sputtering and misfiring as if timing was not right, what could it be? the cps is in the bellhousing of the nv3550 with manual tran stock flywheel so adjustment is very little....what can it be? It's a 4.5
Stock pistons dished to 23 cc
no block shaving
4.2 crankshaft and rods
Hi volume oil pump
Stock camshaft
victor reinz head gasket
Ford 24lb injectors
help me out.......
Re: stroker timing
Post by dwg86 »
What year vehicle?
Re: stroker timing
Its a 93.
Have you taken a look at this: http://www.angelfire.com/my/fan/dist_index.html Note you may need to remove the ears to correctly index it. What plugs are you running?
daccarettfletez
Re: stroker timing
sorry it's a 93 obd1/ I'm using accel u groove plugs and summit racing 8mm cables/ msd 6/ and firepower coil (Had all this before stroking it...)
Re: stroker timing
Post by John »
As mentioned above, the first place to check is the distributor indexing, with a stock cam, you should not have to remove the ears from the dizzy, but check the indexing................
daccarettfletez
Re: stroker timing
thNKS!
Correct! distributor indexing was the culprit! I'll post my experience driving it as soon as I get it back!!! Thanks all for the help on the board...
one more question best plugs for the stroker?
I'm running the accel u groove plugs, I once bought some bosch 4 electrode platinums but they didn't work fine on my 4.0...
Re: stroker timing
Oem or equivelent replacements from NGK, Champion or Autolite. I personally like the champion truck plugs.
Re: stroker timing
I personally like NGKs
StroktWJ
Vehicle Model: Grand Cher
Re: stroker timing
Post by StroktWJ »
I'm running Bosch Platinum's with good luck so far, I have put 350 miles on the 4.6
#727 Crank
Clevite 3415 Pistons
91-95 Camshaft
7120 Head
00 Intake
Magnaflow Muffler
Offroad Pipe
4wdparakeet
Re: stroker timing
Post by 4wdparakeet »
Sorry to drag up an old post but I'm having possibly similar issues and was wondering if you could describe the symptoms in a little more detail.
Parakeet
daccarettfletez
Re: stroker timing(finally took it for a ride)
4wdparakeet sorry for the late response but I haven't had time to check the site...
the problem was indeed bad timing, the symptons where difficult starting, engine misfired badly, backfired, was completely undrivable
the solution:
7 months later...finally test drove it. Couldn't be happier with the new engine, plenty of torque and best of all no pinging yet....(Just drove it on the street for about 45 min)...
Thanks all for the input and great info on the stroker build!!!
regards from Honduras
