Flogging the wee wee out of a Jeep 4.0 I6
SIXPAK
Consistent
Consistent
Stroker Displacement: 280
Re: Flogging the wee wee out of a Jeep 4.0 I6
Post by SIXPAK »
Soon son, be patient! It will be hard to contain the smile under the helmet.
TurboTom
Post by TurboTom »
1979 AMC Spirit
Building a Turbo 2.5
I am not very smart!
good job!
Thats awesome! love the turbo sound
Flash
Post by Flash »
Good shake down video :rockout: :rockout:
so tell me/us more!!!
what happen down track?
what you going to change for the next stomp :stick: :D
Flash
TurboTom
Post by TurboTom »
Flash wrote:Good shake down video :rockout: :rockout:
Flash
The next thing I change will be the top compression rings.
Came back running on 5 after the 3rd pass.
No smoke, just blowby from 1 cylinder.
Got the head off, everything looks 100%. Just no compression on #6
Pretty sure I broke the top ring. They were cheapies.
1979 AMC Spirit
Flash
Post by Flash »
wow, i just thought you lost traction and had to lift :o
Glad to here the damage was minimal.................so how much boost were you pushing when the rings gave up on ya.
Flash
TurboTom
Post by TurboTom »
Just to clear a little confusion.
I was just making some 1/8 mile shake down passes on a 1/4 mile track
With me being rusty and a brand new car I wanted to get a feel for everything.
I did not even know it was on 5 until I stopped to pick up my time slip.
I was running 13 pounds of boost, just like I did on the dyno.
Car drives great, just need a better set of tires (these are 13 years old) and now a set of better rings.
I'm happy with it so far.
1979 AMC Spirit
1bolt
Post by 1bolt »
Damn it dude that Vid has me eye balling my Comanche Work truck with the tired old renix... I've mentioned wanting to do a street strip MJ before but I'm getting impatient, and my work MJ might get replaced with a J-truck, it's a long bed so the wheel base is good... Might even leave the 4wd in it and launch like the deisel trucks do. How does that Spirit feel down the track with the short wheel base? Looked like you blew the tires off on the first shift, or was that just getting out of the groove?
BTW nice looking little car, I could see that thing bruising some Ego's... I'd love to be there the first time you pull some NA big block Chevy running high 12's and they find out they got beat by a straight six tractor engine... You coasted to a 12 second quarter? Man... So any guess as to where it will be when you get past the shake down stage?
Simon
TurboTom
Post by TurboTom »
I found out the tires are 13 years old ! It will be getting new slicks soon.
Drove great, I built alot of caster into my front end design.
Car should run in the 10's when sorted.
1979 AMC Spirit
Post by dwg86 »
I'll be happy to see you smoke some high dollar, small block chevy.
the_wrench116
Post by the_wrench116 »
i will be happy to see him smoke whatever he pulls up next to :banana: :hrhr: :!: :!: :!: :!: :!: :!:
TurboTom
Post by TurboTom »
Broke the ring lands on #6 piston.
Piston is off to Diamond to tell me why.
No signs of detonation...anywhere
1979 AMC Spirit
the_wrench116
SOAB :!: well guess you have a really exotic paper weight. hopefully they will replace it for you. did you look at the others to make sure that they are ok?
Flash
Post by Flash »
TurboTom wrote:Broke the ring lands on #6 piston.
Is there any change the ring gap closed up?
But then again, them cylinders should have been hotter on the Dyno ........But then again, the Dyno pull is less time then it take to travail 1/8 mile :huh:
Sorry arguing with my self :D
