Harland Sharp roller rockers installed
Just got done installing a set of Harland Sharp roller rockers. Haven't fired it yet as it too cold out to put the rest of the engine crap back on. Easy as hell to set the pre load. And they are damn sexy too!
Too bad they don't make a clear valve cover. Meh... At least my valve cover isn't just black.
Re: Harland Sharp roller rockers installed
Looks good. Maybe I'll get a set of RRs in the future.
1bolt
Post by 1bolt »
very nice
Simon
Shark
Consistent
Consistent
Post by Shark »
those look great! how much were they?
'95 XJ 4door 4.0 aw4 2" 31's
Lets just say they were more than I wanted to spend on a set of roller rockers. Then the spacers cost extra too.
Were they easy to install, and what other parts did you need to complete the job? Any machining work to the head?
Flash
Post by Flash »
[quote="SilverXJ"]Just got done installing a set of Harland Sharp roller rockers. Haven't fired it yet as it too cold out to put the rest of the engine crap back on. Easy as hell to set the pre load. And they are damn sexy too!
whats with this pic? Did you start with a differt brand.......and change your mind
And what was the price differance? more or less then the yella's
Flash
Flash
Post by Flash »
Flash[/quote]
That silver one is a Yella Terra. Titan's push rod selection among other issues killed them. When they were new and I put them on the preload was kept the same as the stock stamped steel rockers. However, now they reduce the preload significantly. I only used that one set because it got that particular cylinder to an acceptable preload. The others didn't.
They were more than the YTs. I would have been perfectly happy getting another set of YTs if it had not been for my preload issue.
fedrusion
Learning to use the board
Post by fedrusion »
Did you have to machine the stand offs on the head, or are you using a valve cover spacer so these will fit?
I have been thinking about these rockers but am worried about making sure that the geomety will be right when installed. On Dino's site it mentions that .400 needs to be removed from the head for instalation, is this for rocker geometry or valve cover clearance?
I didn't have to machine anything for them to fit. I am using the valve cover spacer. I noticed that that was aid on Dino's site and i don't understand why. I saw nothing that would require me to take them down .4"
AGRESIVE
Post by AGRESIVE »
They look super sexy! Makes me want a set now!! Anyone want to be a slightly used set of Yella Terra non adjustable roller rockers?! :lol:
Where'd you get them from Chris?
"No good deed goes unpunished!"
I got them from hesco for the simple reason that they had everything I needed.
fedrusion wrote:Did you have to machine the stand offs on the head, or are you using a valve cover spacer so these will fit?
That does apply for the stud-mounted rockers that carry part no. S4096. I believe it's for the guideplates.
The pedestal mount S40196 are a direct, easy bolt-on replacement for the stockers like the YT6627's. There are two types; non-adjustable and adjustable. Silver XJ probably has the latter which require a valve cover spacer if they're bolted to the iron head, but fit under the stock valve cover if they're bolted to the Hesco aluminium head.
Correct, they are the adjustable version, which is why I went with HS over YT this time.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 3 guests
