how fast are yall's strokers?
billy_bob
Learning to use the board
Vehicle Year: 1994
Vehicle Model: cherokee
Post by billy_bob »
I'm in the process of building my stoker and i'm curious to know how much faster is the stroker than the 4.0L, granted different combination do different things. I do plenty of haulen ass in my 4.0 Cherokee and a massive torque upgrade sounds like it would be fun. With a basic (to start with) stroker 4.7, and standard size tires how much haulen ass can i do?
90 block, 94 7120 head and rods, IC944 .060 21cc, comp 68-239-4 and of course the 258 crank. my first full build and i did pretty damn good
Plechtan
Re: how fast are yall's strokers?
Post by Plechtan »
The amount of Haulin ass possible depends on the size of the ass in question.
Peter Lechtanski
Vehicle Make: Jeep XJ
Take a look in my sig. Stock sized 225/70R15 tires, stock 3.07 gears, and 75lb of weight reduction.
George Dickel
Post by George Dickel »
While it won't hang with my Stang, it leaves folks in the rearview on the stoplight grandprix when need be. It's such a different feel anyway. My Stang has 3.27 rearend gears vs 4.11s in the TJ. It does "get up" when needed and impressively. I don't think you'll be let down at all. My problem is that I've never driven any other Jeep and I drove this Tj the first time when I installed the Stroker so I don't have a reference :huh:
'98 Wrangler Sport, 4.6L Stroker
'04 Mustang GT, 4.6L with a few bolt-ons
Heck
Post by Heck »
I've never raced, but the butt dyno is extremely satisfied. It'll spin a pair of 265/75-16 AT's in second gear, lift the left front tire way high up off the ground in a left turn, and my mileage went from 14 to 16.5 mpg (with cam swap). The cruise control can pull the 8% grade near my house in 5th gear.
I NEED MORE TORQUE!
'03 Rubicon w/4.6: kb pistons, late 70's 4 weight crank, Mopar P4529228ab cam, 240 dur./.430 lift, barely polished aluminum head. First fire 11/14/08, eventual mechanical issues, rebuilt January '26.
TurboTom
Post by TurboTom »
I got 500 ft/lbs and 450HP out of my 4.0 turbo.
Went 7.25 @ 100.3 in the 1/8 before it broke a piston ring land.
Going back with hyper pistons and lowering the boost for now.
1979 AMC Spirit
Building a Turbo 2.5
I am not very smart!
SIXPAK
Consistent
Consistent
Stroker Displacement: 280
Post by SIXPAK »
TurboTom wrote:I got 500 ft/lbs and 450HP out of my 4.0 turbo.
Your hairdryer and sleak bullet body style of the spirit only went that fast? Heck my CJ5 stroker went 7.04 @ 98 all motor, what gives TT.
:stick: ( It's OK guys, we rib each other often. really)
TurboTom
Post by TurboTom »
Let me get a trans brake in it so I can get my hairdryer up to speed....Then we will see :smack:
But you are correct, it is a turd.
1979 AMC Spirit
amcinstaller
Vehicle Year: 1980
Vehicle Make: AMC
Vehicle Model: Spirit
Post by amcinstaller »
cheater! thats not a stroker :D im impressed though, if that matters, haha
SIXPAK
Consistent
Consistent
Post by SIXPAK »
I would rather see you run without a brake. You know, just to save you money. ;)
1bolt
Post by 1bolt »
My XJ which is cammed for low torque did a low 15 second quarter, without burnout (wouldn't have helped anyway) neutral dropping at only 2000 RPM's. with an Auto (which coincidentally or not needs replacing now), LSD's front and rear, 3.5" lift 33/12.5/R15 tires (BFG AT KO's) 4.56 gears, 3900lbs with me and a tank of gas... It falls on its face around 4500 RPM's due to the cam being a total RV and towing grind from Clifford. I pretty much did it on a lark, but I'd done previous runs with a G-tech RR with similar numbers (mid to low 15's)
low 15 seconds in a heavy lifted XJ is pretty good IMO and I'm 100% positive I'm making 15 or 20 hp less than Dino because he has a factory Cam and I have the RV cam and his manual trans to my AW4. I'd probably leave on him due to the lower RPM torque peak, and the steep gears and tall tires, he would catch me and blow past on the other end.
To put it in perspective a perfectly bone stock fox body Mustang GT will run in the 14's a little faster than Dino. Which IMO says a lot for how much fun our Strokers are... I am a fan of Mustangs as well (I'm on my 5th)
Tom didn't you say you coasted to a sub 13 second quarter mile on those initial runs because you were shooting for 8th mile times? I guess "turd" is in the eye of the beholder, 12 second quarters without even trying with a hurt engine is impressive to me... That means you have one of the quickest I6's known around these parts and you had your foot off the gas doing it :) heheh.
Simon
TurboTom
Post by TurboTom »
12.10 @ 83 MPH, Lifted just past the1/8 mile.
Sixpak....Thanks for looking out for me. :mrgreen:
1979 AMC Spirit
1bolt
Post by 1bolt »
So you would have cracked into the 11's if you had tweaked the gas a little after the 8th mile.... :slobber:
Simon
TurboTom
Post by TurboTom »
Backed the boost down to 10 lbs.
11.07 @ 122 MPH
1979 AMC Spirit
That's sick--never been in a car that fast(12s in a vortech 5.0).
