.903" vs .904" lifter?
I talked with Lunati and they said that the .903" lifters would work fine in the 4.0L, which takes a .904" lifter. However, now I have advice not to use a .903" lifter. According to the FSM lifter tolerance is .904"-.9045", lifter bore .9055" to .9065", and lifter to bore clearance at .001" to .0025".
So, would you advise using a .903" lifter or not?
Flash
Re: .903" vs .904" lifter?
Post by Flash »
Why are you considering these lifters?
what is, interesting about them? or is this the latest idea on getting more oil on the cam?
http://www.lunatipower.com/ProductGroup ... d=28&pid=2
They are the microtrol lifters. It was hard to find a company that has a lifter made in the US. Lunati's lifters and they have better oil control, and can afford less preload than others.
Post by dwg86 »
Racer Brown sells Stanadyne lifters. They are made in the USA. They are around $60.00 for a set.
oh yeah.. I already have these lifters and trying to figure out if i can use them or not.
amcinstaller
Vehicle Year: 1980
Vehicle Make: AMC
Vehicle Model: Spirit
Post by amcinstaller »
if you have custom length pushrods, why couldnt you use these?
Its the diameter, not the height of the lifters.
I just measured the lunati lifters to be .9036" to .9038", which is the same as a set of engine tech lifters and a set of compcam lifters.
Use them already!
LOL.. as soon as I get the cam.
Here is something interesting. I compared a Lunati, a Crower Cam Saver, an OEM, a Comp Cams and an Engine Tech. All measured .9036" to .9038" except the OEM and Crower. They measured .9044" to .9045"
very interesting...
I would think it all depends on what diameter the bore is in the block...
To big of a clearance could cause what? Lower oil pressure?
Given the same bore diameter a smaller lifter will be able to wobble more, but I don't know if that has any effect. Lower oil pressure perhaps. I have ran several of these lifters in the same block and noticed no real oil pressure difference. Even with the Crower Cam savers and their flat spot I noticed no real oil pressure change. I'm not really certain that the size makes that much of a difference considering the majority are of the smaller size and the most commonly used.
