I'm interested in finding the differences between the main bearings throughout the years...
What makes the early 4.2L bearings different than the recent 4.0L bearings?
Anyone have pictures?
Main Bearing differences
rradford9
- Stroker Displacement: 4.5l
Re: Main Bearing differences
Position of the locating tangs. On the 4.2L and the '87-'90 4.0's the locating tangs are offset. In the '91+ 4.0L's the locating tangs are offset. I have a set of 4.2 mains that I didn't use. You want me to take a picture of them?
4.5L Simple Stroker
* 4.2L crank & rods
* H802CP pistons (18cc dish)
* 9.57:1 SCR / 8.28:1 DCR
* 0.050" Quench
* 62mm TB
* Hot Air Intake
* 2.5" Magnaflow cat and Flowmaster 50
* JBA Header
* 4.2L crank & rods
* 0.050" Quench
* 62mm TB
* Hot Air Intake
* JBA Header
lafrad
that would be great!
lafrad
Doh!
Looks like we lost some momentum here.
360 Oiling:
I'm looking to get a set of bearings where the "Oiling Shell" has the same tang location as the "main cap" on a 1999 4.0L block. THis way, you can install 2 "oiling shells" for each main bearing and get oil pressure to the rod for 360* of crankshaft rotation. If it is something as easy as "buy a set of 4.2L main bearings and mix/match" I would LOVE it. 360 oiling means 360* of oil pressure on the rod, and 360* of oil slinging off each rod to throw at the camshaft.
360 Oiling:
