Off topic, play nice. No Nudity, Pornographic material etc..
		Posts:  1353Joined:  February 13th, 2008, 5:33 pmStroker Displacement:  4.6/280ciVehicle Year:  1996Vehicle Make:  JeepVehicle Model:  CherokeeLocation:  DC
						Post
								by gradon  September 7th, 2009, 12:26 pm
			This is the the block I yanked from the 96 that I bought off CL for $160(I installed the 75K 4.0 from my 96 and made a nice profit).  I finally removed the head so I could start the P&P for my brother's manche project.
		Posts:  1506Joined:  January 8th, 2008, 10:55 amStroker Displacement:  4.7LVehicle Year:  1990Vehicle Make:  JeepVehicle Model:  CherokeeLocation:  Oregon
						Post
								by Muad'Dib  September 7th, 2009, 3:25 pm
			Id bolt it back up and run it .. it should be fine like that
		Posts:  5790Joined:  February 14th, 2008, 7:14 amStroker Displacement:  4.6LVehicle Year:  2000Vehicle Make:  JeepVehicle Model:  CherokeeLocation:  Radford, Va
						Post
								by SilverXJ  September 7th, 2009, 5:18 pm
			Looks like its part of the Jeep's top secret MDS system utilizing an infinite dish piston to eliminate compression. The hole should close up when its running.
								amcinstaller
		Posts:  635Joined:  May 22nd, 2008, 11:57 pmStroker Displacement:  4.6LVehicle Year:  1980Vehicle Make:  AMCVehicle Model:  SpiritLocation:  Red Deer, AB, Can
						Post
								by amcinstaller  September 7th, 2009, 7:40 pm
			imagine the boost you could run with that piston!!! such low compression would be great!!
SilverXJ wrote: Roller rockers won't help that mess you have created. Nor will God for that matter.
						Post
								by gradon  September 8th, 2009, 11:46 am
			I forgot to mention that when attempting to start this engine, the dipstick would blow out.
								PolloLoco
		Posts:  212Joined:  March 8th, 2009, 6:39 amStroker Displacement:  4.7LVehicle Year:  1997Vehicle Make:  JeepVehicle Model:  TJLocation:  DeRidder, LA
						Post
								by PolloLoco  October 5th, 2009, 10:23 pm
			At the airport once I had a European ask me if my TJ was diesel or petrol.  I can't wait to find what's inside my block but I bet it won't be that bad.
						Post
								by gradon  October 6th, 2009, 6:32 pm
								yuppiexj
		Posts:  319Joined:  February 13th, 2008, 7:31 pmStroker Displacement:  4.5 needs assemblyLocation:  Fredercksburg VA (land of nothing)
						Post
								by yuppiexj  October 6th, 2009, 7:14 pm
			you suck... I mean good find there.
							TurboTom wrote: i will eat my words later if need be.
TurboTom wrote:
Not sure of your rules...but you need to start with an engine that works best for the rules and cheat from there!
						Post
								by gradon  October 6th, 2009, 10:18 pm
			#1 was a 96 w/ 122K and that hole in the piston for $160: swapped in the 72K motor that I took out of my 96.  #2 was a 95 Upcountry w/202K w/ "seized engine" that had a bad nss for $200.  #3 was a 95 sport w/196K that had a blown HG and needed a head shave and valve job for $300.  And the above is #4.  Finally my years of Jeep experience is paying off!  1995 Avus Blue M3 once I sell this!
