Custom Pistons Recommendation
bbarrett
Stroker Displacement: 331
Vehicle Year: 1987
Post by bbarrett »
OK i asked this question a while back, But really hadn't made up my mind as to how i was going to build. Now i have.
Here is what i have, 87 renix block, deck height of 9.447. 1980s 258 4 cw crank. Going to use the 4.0 rods. according to my calculations I'm going to need a piston height of 1.376 in order to get a 0 deck height. And 23 cc dish to keep the compression down in the 9s.Now for the question, Does anyone recommend a specific piston manufacturer? If so why? I am thinking of going with the diamond pistons unless someone can tell me different. Although i have not yet talked to the guys at 505 performance yet, They claim they have a set of Eagle rods and pistons for 1100.00 dollars. Which if this is the case and they are of the correct compression height i will be getting these. Unless someone can give me a better scenario. Any and all comments will be greatly appreciated.
Thanks in advance.
TEST
Stroker Displacement: 4.9
Re: Custom Pistons Recommendation
Post by jsawduste »
Diamond racing
Post by dwg86 »
You can also look at the Keith Black 944's.
lafrad
Post by lafrad »
CP makes GREAT pistons, have used them before.
They get a little pricey, however.
bbarrett
Vehicle Year: 1987
Post by bbarrett »
dwg86 wrote:You can also look at the Keith Black 944's.
Wrong compression height, But thanks anyway for the comment.
bbarrett
Vehicle Year: 1987
Post by bbarrett »
lafrad wrote:CP makes GREAT pistons, have used them before.
Do they take custom orders? They cant be much higher than diamond. $130.00 per piston is what they quoted me. But thanks for the comment.
TEST
Post by dwg86 »
BRC Pistons. I've never used them, but talked to them back in June.
http://www.jeepstrokers.com/forum/viewt ... rc+pistons
Bodo
Post by Bodo »
dwg86 wrote:BRC Pistons.
Take my advice and don't waste your money. BRC used to be a decent manufacturer, but not anymore. Utter Crap.
bbarrett
Vehicle Year: 1987
Post by bbarrett »
Advice taken, Thanks
TEST
Users browsing this forum: Amazon [Bot], Semrush [Bot] and 4 guests
