Possible build plans
TNT
Where's the "any" key?
Post by TNT »
Possible stroker plan
~ Jeep 4.2L 3.895" stroke crank(early heavy weight one)
~ Jeep 4.0L 6.125" rods
~ Custom +0.030" bore pistons with 1.38" pin height & 25cc dish
~ 9.6:1 CR
~ Mopar Performance 0.043" head gasket
~ 0.043" quench height
~ Ported big valve 2.02"/1.60" cylinder head
- Mopar Performance P5249519 Double Roller Chain and Sprocket Set
~ Mopar Performance P4529229AB Adv Duration: 248/248 Lift: 0.440/0.440 O-lap: 40 Center line: 108 centerline
- Mopar Performance 5249464 valve springs
- Mopar Performance oil pump
~ Oversized thottle body
~ LT-1 24lb/hr injectors with adjustable FPR
- Borla Header, Dynomax high flow cat and a Flowmaster 40 series muffler
Your input is welcome
TNT
89 MJ ext. cab project
Life's Journey isn't to arrive at the Grave Safely in a Well Preserved Body. But Rather to Blast Full Throttle, Launch Airborne, Land Hard, Slide in Sideways, Totally Worn Out & Thrashed, Screaming Holy $hit What a Ride!
Shark
Consistent
Consistent
Re: Possible build plans
Post by Shark »
are you shooting for that CR or is this an estimate? why not try for closer to stock? the reason i ask is that when i build my stroker i dont want to have to run premium.
'95 XJ 4door 4.0 aw4 2" 31's
TNT
Post by TNT »
tigerShark wrote:are you shooting for that CR or is this an estimate? why not try for closer to stock? the reason i ask is that when i build my stroker i dont want to have to run premium.
It's an estimate that I have found doing research. I will measure it all during mock-up and if It's too high I'll run a bigger cam with more duration to reduce cylinder pressures.
TNT
Shark
Consistent
Consistent
Post by Shark »
what octane do you anticipate running with that setup?
TNT
Post by TNT »
tigerShark wrote:what octane do you anticipate running with that setup?
    I'll get it to run on 87 octaine. I'll go big on the cam if I have to, worst case I would add meth/water injection at a 50/50 mix during heavy loads..
    TNT
    Shark
    Consistent
    Consistent
    Post by Shark »
    will going big on the cam hurt low end torque?
    TNT
    Post by TNT »
    tigerShark wrote:will going big on the cam hurt low end torque?
    It is going into a '89 with 5.13 gears and 35" tires. My AW-4's stall is high enough that the it may have less torque then a high torque cam, but will match a stock 4.0's output if not have more. I want it to pull hard in the mid rpm to redline. My build will be more like a prerunner/JeepSpeed type rig.
    Shark
    Consistent
    Consistent
    Post by Shark »
    that sounds like a cool setup. most guys who build these motors are looking for massive low end. nice to see you looking for HP. is this going in a daily driver?
    TNT
    Post by TNT »
    tigerShark wrote:that sounds like a cool setup. most guys who build these motors are looking for massive low end. nice to see you looking for HP. is this going in a daily driver?
    It will be a DD sometimes. I'm thinking of doing a 18" travel front suspension and a 28" travel rear suspension.
    It's getting a HP D44 and a 9" for axles. Need HP to go fast.
    TNT
    How much are your pistons? I still have yet to decide if I'm gonna use the 4.2 rods that I have with stock(if bores are good) or .030" over pistons or the 4.0 rods and the KBs(if they make them). I'm also not sure about the big valves as apparently there are shrouding issues(have you already had them done?). Other than that, I plan on using the Mopar 30 cam, .043 HG, with a close to zero deck height, and have high compression ratio. I plan on having to use premium fuel.
    TNT
    Post by TNT »
    Sorry about not repling I have been to busy dealing with doctors about my heart and a pinched nerve in my neck.
    I haven't had time to do anything to my strocker project.
    TNT
    That's similar to my build--I'm gonna deck the block .025", which leaves the piston .0045" below deck, so almost a zero deck. I will be using the slightly bigger 30ab cam. I will use the 4-weight crank. My head is ported, but am not using bigger valves. The pistons I will use have a 21.7cc dish. SCR will be ~9.7:1, DCR~8.2-3:1, and I plan on using premium gas.
