ways to boost torque
cjackson3396
Where's the "any" key?
Post by cjackson3396 »
I'm working on a 4.7 Budget built stroker. Just looking for some ideas on ways to boost the torque a bit more.. I was getting 315lb.
Re: ways to boost torque
Post by John »
Cam selection, 99 intake helps uniform the torque curve, Borla long tube headers. What is the primary end use of this build?
cjackson3396
as of right now it would be my dd...I'm want to try and give it a boost so I can actually make it up a hill (5speed) I'm not looking for monster torque or power or climbing rig stats. I want to try and keep the jeep as economical as I can while giving it that little boost. It has to turn 35inch tires.
yuppiexj
Post by yuppiexj »
what gears are you running?
cjackson3396
Thats my next upgrade...right now I beleive the gears are stock...The previous owner said the rearend is out of a 2000 but i'm not sure...I have the stock 96 gears but he welded up the spider gear.
Post by John »
You will see a great improvement if you match gears with those 35's.
cjackson3396
So what would you suggest for gears....My ranger had 35s and 4:56 ratio..
yuppiexj
Post by yuppiexj »
I'd throw the lowest gears you can into it.
I ran 4.56s and 32s in my stock engined 88 Cherokee with the OD automatic and it was very nice to drive (MPGs went over 20 on the highway).
cjackson3396
WOW...I'm getting mybe 15-17mpg if i'm lucky
Post by John »
cjackson3396 wrote:So what would you suggest for gears....My ranger had 35s and 4:56 ratio..
That would be a good selection for a daily driver, should put you back close to the OEM performance with factory gears and tire sizes.
cjackson3396
Could I use the 4:10 gears out of a wrangler?
YJason
Post by YJason »
I run 33's and 4:10's and get 14 ish around town and 17 hwy (60-65mph) 4.6 stroker and AW4 in a wrangler. I like the way it is geared.
cjackson3396 wrote:as of right now it would be my dd...I'm want to try and give it a boost so I can actually make it up a hill (5speed) I'm not looking for monster torque or power or climbing rig stats. I want to try and keep the jeep as economical as I can while giving it that little boost. It has to turn 35inch tires.
I have stock sized 27.4" tires with stock 3.07 gears and the balance is just about perfect. Since you have 35" tires, I'd say you need 4.10's. If the Wrangler has the same axles you can use the gears from those.
tomcat
Post by tomcat »
any 2.5 4 banger would have 4.10 gears too, not just a wrangler
Biggrnjeep97
Post by Biggrnjeep97 »
I daily'd 4.56s on 33, 35, and 37 mtrs over a period of bout 6 years. IMO they where just tad (~200rpm) high on the highway with the 35's and a bit low (~2-300rpm) with the 37's. However the highways in my area require you to run 70+ or your gettin run over so if your lookin for 60mph and 35's id say 4.56's are your best bet. BTW I had an AX-15 w/ .79 OD ratio.
-Will
