Hesco Springs
Bodo
Hesco Springs
Post by Bodo »
Hey Gang
Really not trying to lose my cool over this...But I ordered a set of HESSPRSS6 springs from HESCO.
Description from website:
Provides higher spring pressures/height when installing performance cam shafts. Provides better protection against breakage with high performance engines running at higher RPMs.
NOTE: Machining is required to properly set installed height. Single groove valves only. 1997-Up 4.0L Jeep engines have triple groove vales and must purchace single groove valves in order to use this kit.
This leads me to believe that they will fit any of the 4.0 heads, but the pad would need to be machined to achieve proper pressure.
I got them over the weekend. Lo and behold, they are the same SBC RV springs and retainers that we carry on the shelf! If I wanted SBC springs, I wouldn't have spent $151 on them...
Plechtan
Re: Hesco Springs
Post by Plechtan »
Maybe you should return them.
Peter Lechtanski
Bodo
Re: Hesco Springs
Post by Bodo »
Oh I will be. I'm going to give them the opportunity to explain themselves. I really am hoping that they screwed up and sent the wrong stuff.
Plechtan
Re: Hesco Springs
Post by Plechtan »
Maybe you should go with these, http://www.jeepstrokers.com/forum/viewt ... f=5&t=1433no need to change the valves.
Peter Lechtanski
Bodo
Re: Hesco Springs
Post by Bodo »
Plechtan wrote:Maybe you should go with these, http://www.jeepstrokers.com/forum/viewt ... f=5&t=1433no need to change the valves.
I thought about going with those, but I already have the valve job done with the single groove valves. Still waiting to hear back from Bennie.
Re: Hesco Springs
Couldn't you find a lock for the single groove valves?
lafrad
Re: Hesco Springs
Post by lafrad »
There are 8* single grove locks with a similar install height somewhere. I do not have the part number for them
Bodo
Re: Hesco Springs
Post by Bodo »
Forget about getting HESCO to reply to any emails.
I'll be returning the springs, which apparently are 'specially' made Chevy springs, but I will be keeping the retainers. They're kind of neat.
With those you can use Jeep valves and keepers along with Chevy springs.
I'm going to call shenanigans on the 'specially' made thing, though. They are the same spring rates and dimensions as the Chevy RV springs I carry and sell for $1.75 :doh:
Re: Hesco Springs
Any useful part number you could share?
Bodo
Re: Hesco Springs
Post by Bodo »
Our part number is: RV943x100 we get them from MR Engine Parts in Jacksonville, FL.
Users browsing this forum: Bing [Bot], Google [Bot] and 3 guests
